MSI NF750-G55 Motherboard Review
November 19, 2009 | 09:41
Tags: #am3 #analysis #benchmarks #board #g55 #mobo #motherboard #nforce #oc #overclock #overclocking #performance #result #review #sli
Companies: #amd #msi #nvidia #test
Lavalys Everest 5.0.1667 Memory Performance
Website: Lavalys
Everest Memory Performance Test
  • MSI 770-C45
  • Asus M4A785TD-V Evo
  • MSI NF750-G55
    • 8183.0
    • 6680.0
    • 9898.0
    • 8017.0
    • 6532.0
    • 10236.0
    • 7701.0
    • 6659.0
    • 9082.0
5000
7500
10000
MB/s (higher is better)
  • Read MB/s
  • Write MB/s
  • Copy MB/s
Everest Memory Performance Test (OC)
  • MSI NF750-G55
  • MSI 770-C45
    • 10337.0
    • 8642.0
    • 12276.0
    • 9494.0
    • 7424.0
    • 11450.0
    • 8999.0
    • 7434.0
    • 11163.0
5000
7500
10000
12500
  • Read MB/s
  • Write MB/s
  • Copy MB/s
Everest Latency Test
  • MSI 770-C45
  • MSI NF750-G55
    • 55.3
    • 49.1
    • 55.6
    • 47.3
    • 56.9
    • 44.9
20
30
40
50
60
Nanoseconds (lower is better)
  • Stock
  • Overclocked
Stock memory performance is considerably lower than the AMD chipset motherboards, despite the fact the memory controller is within the CPU and we're using the same hardware across the range, the BIOS has clearly not been optimised as is shown in the 300-400MB/s drop in memory performance and the 10 per cent loss of copy performance.
Overclocked, and the MSI board offered performance in line with 790FX motherboards twice the price: we achieved a 2.6GHz stable CPU-northbridge and 1,600MHz memory at its stock CAS-8 settings that yielded a considerable performance boost over the other boards.
These results are also mirrored in the latency results too: slow at stock, but nippy when overclocked.
SiSoftware Sandra Lite 2009 SP3 Home Professional
Website: Sisoftware
Sisoft Sandra Unbuffered Memory Test
  • MSI 770-C45
  • MSI NF750-G55
    • 12596
    • 13883
    • 12375
    • 14468
    • 11439
    • 15462
5000
7500
10000
12500
15000
17500
  • Stock
  • Overclocked
Sisoft Sandra Random Memory Latency Test
  • MSI 770-C45
  • MSI NF750-G55
    • 85
    • 75
    • 86
    • 69
    • 88
    • 69
20
30
40
50
60
70
80
90
  • Stock
  • Overclocked
Sisoft Sandra's multi-threaded tests tells much the same story, but to a larger degree: very poor stock performance that turns into a huge increase when overclocked.
