MSI P55 GD65 Review
September 11, 2009 | 11:18
Tags: #benchmarks #core #ddr3 #gd65 #i5 #lga1156 #mobo #motherboard #oc #overclock #p55 #perform #result #review
Companies: #msi #test
Crysis
Publisher: Electronic Arts
We tested the game using the 64-bit executable under and DirectX 10 with the 1.21 patch applied. We used a custom time demo recorded on the Harbour map which is more representative of gameplay than the built-in benchmark that renders things much faster than you're going to experience in game.
For our testing, we set all the settings to High. Because of how intense the game is, we tested with both anti-aliasing and anisotropic filtering disabled at resolutions above 1,680 x 1,050 for the time being. There is currently no support for anisotropic filtering in the game, but you can still force it from the driver control panel.
Crysis
1680x1050 2xAA 0xAF, All High Settings, Zotac GeForce GTX 260 AMP!
  • MSI P55 GD65
  • Asus P7P55 Deluxe
    • 34.0
    • 23.7
    • 33.5
    • 21.0
10
15
20
25
30
35
Frames Per Second - higher is better
  • Average
  • Minimum
Crysis (CrossFireX)
1680x1050 2xAA 0xAF, All High Settings, Sapphire Radeon HD 4870 1GB Toxic
  • Asus P7P55 Deluxe
  • MSI P55 GD65
    • 41.3
    • 26.5
    • 39.0
    • 23.0
20
30
40
  • Average
  • Minimum
Crysis (SLI)
  • MSI P55 GD65
  • Asus P7P55 Deluxe
    • 50.4
    • 29.9
    • 47.6
    • 28.8
20
30
40
50
  • Average
  • Minimum
Crysis performance is back and forth between the two boards across the single and multi-GPU tests at stock speeds. Out of the three scenarios the MSI draws a lead with Nvidia cards installed, however Asus crawls back to lead in CrossFire.
Far Cry 2
Publisher: Ubisoft
Far Cry 2 is the latest first person shooter from Ubisoft, and while it continues the Far Cry franchise that Crytek started in 2004, this game is built on its own in-house engine and has no association - other than its name - to anything Crytek has worked on or is working on now. We used a retail version of the game patched to version 1.02, and used the in-built "Action" gameplay demo set to Ultra-Very High settings under DirectX 10.
Far Cry 2
1680x1050 DX10 0xAA 0xAF, UItra High Settings, Zotac GeForce GTX 260 AMP!
  • MSI P55 GD65
  • Asus P7P55 Deluxe
    • 48.1
    • 38.8
    • 46.9
    • 39.7
20
30
40
50
  • Average
  • Minimum
Far Cry 2 (CrossFireX)
1680x1050 DX10 0xAA 0xAF, UItra High Settings, Sapphire Radeon HD 4870 1GB Toxic
  • MSI P55 GD65
  • Asus P7P55 Deluxe
    • 48.1
    • 38.8
    • 46.0
    • 39.0
20
30
40
50
  • Average
  • Minimum
Far Cry 2 (SLI)
  • MSI P55 GD65
  • Asus P7P55 Deluxe
    • 57.8
    • 46.6
    • 56.6
    • 46.8
20
30
40
50
60
  • Average
  • Minimum
In Far Cry 2 the MSI has a consistently slightly faster average frame rate, but the Asus board gives a marginally smoother experience with a higher minimum in every situation. The differences are again minimal though.
