Publisher: Electronic Arts
We tested the game using the 64-bit executable under and DirectX 10 with the 1.21 patch applied. We used a custom time demo recorded on the Harbour map which is more representative of gameplay than the built-in benchmark that renders things much faster than you're going to experience in game.
For our testing, we set all the settings to High. Because of how intense the game is, we tested with both anti-aliasing and anisotropic filtering disabled at resolutions above 1,680 x 1,050 for the time being. There is currently no support for anisotropic filtering in the game, but you can still force it from the driver control panel.
MSI P55 GD65
Asus P7P55 Deluxe
Frames Per Second - higher is better
Asus P7P55 Deluxe
MSI P55 GD65
Asus P7P55 Deluxe
MSI P55 GD65
Overclocked, and again the MSI leads with a single GeForce GTX 260 installed, but the Asus draws out a slight lead in both SLI and CrossFire, with both higher averages and minimums.
Publisher: Ubisoft
Far Cry 2 is the latest first person shooter from Ubisoft, and while it continues the
Far Cry franchise that Crytek started in 2004, this game is built on its own in-house engine and has no association - other than its name - to anything Crytek has worked on or is working on now. We used a retail version of the game patched to version 1.02, and used the in-built "Action" gameplay demo set to Ultra-Very High settings under DirectX 10.
Asus P7P55 Deluxe
MSI P55 GD65
Asus P7P55 Deluxe
MSI P55 GD65
Asus P7P55 Deluxe
MSI P55 GD65
20
30
40
50
60
70
80
By all accounts, the MSI loases out to the Asus board which has either a faster average, minimum or both, by at least a couple of frames per second. Again its slight advantage in base-clock and CPU-NB frequency gives it the edge in multi-GPU situations.
