MSI P55 GD65 Review
September 11, 2009 | 11:18
Tags: #benchmarks #core #ddr3 #gd65 #i5 #lga1156 #mobo #motherboard #oc #overclock #p55 #perform #result #review
Companies: #msi #test
Lavalys Everest 5.0.1667 Memory Performance
Website: Lavalys
Everest Memory Performance Test
  • MSI P55 GD65
  • Asus P7P55 Deluxe
    • 12907.0
    • 10756.0
    • 14604.0
    • 12309.0
    • 10253.0
    • 13827.0
5000
7500
10000
12500
15000
MB/s (higher is better)
  • Read MB/s
  • Write MB/s
  • Copy MB/s
Everest Memory Performance Test (OC)
  • MSI P55 GD65
  • Asus P7P55 Deluxe
    • 18894.0
    • 15341.0
    • 20514.0
    • 16764.0
    • 15584.0
    • 19361.0
10000
15000
20000
  • Read MB/s
  • Write MB/s
  • Copy MB/s
Everest Memory Latency Test
  • MSI P55 GD65
  • Asus P7P55 Deluxe
    • 53.1
    • 38.0
    • 55.1
    • 41.7
20
30
40
50
60
Nanoseconds (lower is better)
  • Stock
  • Overclocked
MSI's BIOS automatically set the Corsair 1,600MHz CL8 memory at 1,333MHz CL9, just like the Asus board, but its core performance is still better in all areas of raw numbers and latency. Overclocked the Asus was pushed to a 200MHz base clock, affording a higher CPU-northbridge clock and memory performance of 2,000MHz at CL8, however the MSI at 190MHz base clock and 1,900MHz CL8 memory actually generates a slightly faster result in everything bar write performance, but that's almost entirely dependent on base clock and CPU-northbridge clock so understandable.
SiSoftware Sandra Lite 2009 SP4 (15.125) Pro Business
Website: Sisoftware
SiSoft Sandra Memory Bandwidth
  • Asus P7P55 Deluxe
  • MSI P55 GD65
    • 16052.0
    • 19174.8
    • 16043.3
    • 22428.5
10000
15000
20000
25000
  • Stock
  • Overclocked
SiSoft Sandra Memory Latency
  • MSI P55 GD65
  • Asus P7P55 Deluxe
    • 74
    • 53
    • 81
    • 59
20
30
40
50
60
70
80
90
  • Stock
  • Overclocked
Sisoft Sandra might say that both the boards performance almost identical at stock speeds, but the MSI obliterates the Asus when overclocked, as it also knocked several nanoseconds off the latency numbers in both cases too.
