File Compression & Encryption:
Website: WinRAR
We used the Intel X25-M SSD to provide a uniform performance base between all the boards tested in file compression and decompression.
MSI P55 GD65
Asus P7P55 Deluxe
Seconds (lower is better)
MSI P55 GD65
Asus P7P55 Deluxe
20
30
40
50
60
70
80
Again both boards perform almost identically when at stock speeds, but consistently the Asus is faster by five seconds or around ten per cent in the two tests.
File Decompression & Decryption:
The two RAR archives created during the compression and encryption tests were then decompressed and decrypted.
MSI P55 GD65
Asus P7P55 Deluxe
Asus P7P55 Deluxe
MSI P55 GD65
Overall we think the MSI loses out to the P7P55D Deluxe here, as it commands a slight and consistent advantage when overclocked. Clearly the SATA performance picks up when under load as we use the same Intel X25-M SSD in this test as we do to check the raw bandwidth numbers.
