MSI P67A-GD65 Review
Written by Paul Goodhead
January 13, 2011 | 12:39
Tags: #best #best-motherboard #comparison #fastest #how-to-overclock #lga1155 #overclocking #performance #sandy-bridge
Companies: #msi
Manufacturer: MSI
UK price (as reviewed): £139.95 (inc VAT)
US price (as reviewed): $179.99 (ex tax)
Intel’s new LGA1155 CPUs are blazingly fast and ludicrously overclockable – two traits that are sure to make bit-tech readers salivate. A CPU is nothing without a motherboard to unlock its potential, however, so it’s no surprise to see motherboard manufacturers fluttering their eyelashes in an attempt to secure your business. MSI’s first entry into what’s sure to be a highly competitive market is the P67A-GD65.
At first glance, the GD65 looks as though it’s been stripped back to the basics, but this is largely due to the fact that the GD65’s heatsinks are less ostentatious than those of the Asus P8P67. This gives the board a slightly more austere feel, which probably isn’t what you want from your new powerhouse PC.
There are valid reasons why the GD65’s heatsinks are so diminutive, though, as the board uses MSI’s clever Icy Choke technology.
These chokes run up to 20˚C cooler than normal chokes and, when combined with the heat-tolerant ‘High-c’ capacitors MSI uses, they allow MSI to get away with small, compact VRM cooling. This means that there’s plenty of room around the GD65’s CPU socket, so we had none of the cooler-mounting problems we had with the cheaper P8P67.
MSI has also sensibly left plenty of room between the two SLI- and CrossFire-certified 16x PCI-E slots, and important connectors such as the 24-pin ATX power socket and fan headers are located near the edge of the board. MSI has also mounted the eight SATA ports, four of which support SATA 6Gbps, parallel with the board for easy cabling.
Some silly mistakes have crept into the design, however. The CMOS battery is right next to the primary 16x PCI-E slot, for example, which means that it won’t be accessible if you use a dual-slot graphics card cooler. MSI has also chosen to give all the SATA 6Gbps ports on the board the same colour, which makes it difficult to determine which two ports are linked to the P67 chip, and which to the Marvell 9128 chip.
This is important, as we saw large differences between the two sets of ports. The ports provided by the P67 chipset read and write data at 295MB/sec and 227MB/sec respectively, while the dawdling Marvell-powered ports are capable of only 270MB/sec and 123MB/sec.
*MSI P67A-GD65 Review MSI P67A-GD65 Review
MSI also includes a number of overclocking-friendly features, such as on-board Power and Reset switches, and a Clear CMOS button on the rear I/O panel. The GD65 even plays host to dedicated voltage readout sockets in the upper right of the board, so that extreme overclockers can check the amount of current coursing through the board. These enthusiast-level features account for some of the extra £20 that the GD65 costs over the P8P67.
Specifications
  • Chipset Intel P67
  • CPU support LGA1155 Core i3, Core i5 and Core i7
  • Memory support 4 slots: max 32GB DDR3 (2,400MHz)
  • Expansion slots Two 16x PCI-E 2.0 slots (one 16x or two 8x), two PCI, three 1x PCI-E
  • Sound Intel HD Audio via Realtek ALC892 with 8-channel support
  • Networking Realtek 8111E Gigabit Ethernet
  • Overclocking CPU Clock 80 – 999MHz; max voltages, CPU 1.8V, CPU IO 1.55V, RAM 2.4V, CPU PLL 2.4V, System Agent 1.58
  • Ports 4 x SATA 3Gbps, 4 x SATA 6Gbps, PS/2, 14 x USB 2, 4 x USB 3, 2 x FireWire, LAN, 4 x surround audio out, line in, mic, optical S/PDIF out, coaxial out
  • Dimensions (mm) 305 x 244 (ATX)
