Lavalys Everest 4.60.1540 Beta Memory Performance
Website: Lavalys
Everest Memory Performance Test
  • Foxconn Blood Rage
  • Gigabyte GA-EX58-DS4
  • MSI X58 Pro
  • Asus P6T Deluxe
  • MSI Eclipse SLI
  • Gigabyte GA-EX58-UD4P
    • 14282
    • 12111
    • 14339
    • 12737
    • 9732
    • 13795
    • 12642
    • 9651
    • 13796
    • 12388
    • 9630
    • 14075
    • 12159
    • 9637
    • 13771
    • 12113
    • 9620
    • 13467
5000
7500
10000
12500
15000
MB/s (higher is better)
  • Read (MB/s)
  • Write (MB/s)
  • Copy (MB/s)
Everest Memory Latency Test
  • Asus P6T Deluxe
  • MSI Eclipse SLI
  • MSI X58 Pro
  • 36.9
  • 37.9
  • 38.1
  • 38.1
  • 38.2
  • 38.7
20
30
40
Nanoseconds (lower is better)
All the stock-speed tests were carried out with the Corsair Dominator test kit with CAS of 6 and the other latencies set to 5-5-15 1T. Like the Eclipse, the X58 Pro won't allow a CAS latency of less than 6. The only X58 board we’ve seen that really pulled away from the pack in the single-threaded Everest test was the Foxconn Blood Rage. While not on a par with Foxconn’s Überclocker, the X58 Pro faired very well despite it being much cheaper than other boards we’ve seen: notably the Gigabyte UD4P that we have previously recommended.
SiSoftware Sandra Lite 2009.SP1 Beta (15.42)
Website: Sisoftware
Sisoft Sandra Unbuffered Memory Test
  • Asus P6T Deluxe
  • MSI Eclipse SLI
  • MSI X58 Pro
  • 20180.3
  • 20037.8
  • 19918.2
  • 19896.5
  • 19845.0
  • 19824.6
10000
15000
20000
Sisoft Sandra Random Memory Latency Test
  • Asus P6T Deluxe
  • MSI X58 Pro
  • MSI Eclipse SLI
  • 72
  • 72
  • 73
  • 74
  • 74
  • 74
20
30
40
50
60
70
80
In SiSoft’s Sandra multithreaded random memory latency tests, the X58 Pro was joint top with the Asus P6T Deluxe whereas, in Everest’s single-threaded memory latency test, the X58 Pro was the second slowest of the X58 boards we’ve seen thus far. More bad news was reported in the memory bandwidth department where the X58 Pro racked up the lowest raw number of any X58 board we’ve tested, if only by a small margin.
Corsair HS60 Haptic Headset Review
October 15 2020 | 14:00
