Publisher: Electronic Arts
We tested the game using the 64-bit executable under and DirectX 10 with the 1.21 patch applied. We used a custom timedemo recorded on the Harbor map which is more representative of gameplay than the built-in benchmark that renders things much faster than you're going to experience in game.
For our testing, we set all the settings to High.  Because of how intense the game is, we tested with both anti-aliasing and anisotropic filtering disabled at resolutions above 1,680 x 1,050 for the time being.  There is currently no support for anisotropic filtering in the game, but you can still force it from the driver control panel.
        Asus P6T Deluxe
        Gigabyte GA-EX58-UD4P
        MSI Eclipse SLI
        MSI X58 Pro
        Foxconn Blood Rage
        Gigabyte GA-EX58-DS4
            41.4
            39.7
            39.5
            39.3
            39.2
            38.8
    Frames Per Second - higher is better
It would be fair to say that most people looking to be relatively earlier adopters of Core i7 will be doing some gaming, so it's good to see that this more affordable board didn’t crash and burn when we fired up
Crysis. It’s not the fasted board we’ve seen but it was a hair's breadth in from of the Blood Rage and also faster than the Gigabyte GA-EX58-DS4.
Publisher: Ubisoft
Far Cry 2 is the latest first person shooter from Ubisoft, and while it continues the
Far Cry franchise that Crytek started in 2004, this game is built on its own in-house engine and has no association - other than its name - to anything Crytek has worked on or is working on now. We used a retail version of the game patched to version 1.02, and used the in-built "Action" gameplay demo set to Ultra-Very High settings under DirectX 10.
        MSI X58 Pro
        Asus P6T Deluxe
        Foxconn Blood Rage
        MSI Eclipse SLI
Interestingly, the X58 Pro produced the slowest minimum frame rate in
Far Cry 2 by a fair margin, although the average frame rate was the highest. This points towards inconsistent performance, though not to such a degree that the game isn't playable but the minimum number is significantly lower than the rest of the boards tested, whereas the higher average is not that much greater.
