Audio Performance
The audio performance tests were done using Audio Rightmark 6.0.5 and a 3.5mm gold plated, oxygen free stereo loop back cable between stereo out and microphone input. Results were taken at the DVD sample rate of 16-bit/48KHz and High Definition 24-bit/96KHz.
What we're looking for:
- Noise Level: A higher negative is better. This is usually viewed in relation to a signal level which provides a signal to noise ratio. As you get closer to zero there's more noise and lesser audio fidelity.
- Frequency Response: Two values listing how close to the lower higher frequencies the codec can reach. If it hits them perfectly it'll display a 0, 0.
- Dynamic Range: The difference between the loudest and quietest sounds the codec can make before it distorts them. The larger the gap, the better.
- THD and IMD percentage: Closer to zero is better. THD and IMD are best looked at together, where as if you have a lot of THD and not much IMD, then it'll offer a warmer accurate sound. High THD and IMD provides a warm, inaccurate sound, low THD and high IMD gives a cold inaccurate sound and finally low THD and IMD gives a cold accurate sound.
- IMD = intermodulation distortion and is a fancy way of saying conversion interpolation, which is a basic detection of the quality loss after an analogue to digital then digital to analogue conversion. By comparing it to a highly compressed source it shows up problems with the codec and converters.
- THD = total harmonic distortion, which shows up unwanted harmonics; integer multiples of the original component sound that can be second, third, fourth degrees or overtones for example.
- Stereo Crosstalk: where the stereo channels "talk" to each other and interact. Ideally you want them entirely separate, unmixed or echoed in either channel, so a higher negative a result as possible is preferred.
16-bit / 48KHz
  Crosstalk, Dynamic Range and Frequency Response
  Intermodulation Distortion, Noise Level and Total Harmonic Distortion
Intermodulation Distortion, Noise Level and Total Harmonic Distortion24-bit / 96KHz
The output quality fits exactly where we expected it to - below the premium ALC885 yet above the ALC883. Overall the noise level is pretty high however you'll always be better off with a discrete solution if you really care for audio that should hit over 100dBA. Either that, or output all audio over HDMI and use a separate amp to deal with it, but then expect budgets to rise accordingly.
Zotac doesn't provide any extra Dolby or DTS features however, it's merely the basic, no frills codec that simply gives two, four, 5.1 or 7.1 channel surround sound.
