Publisher: Electronic Arts
We tested the game using the 64-bit executable under and DirectX 10 with the 1.21 patch applied. We used a custom time demo recorded on the Harbour map which is more representative of gameplay than the built-in benchmark that renders things much faster than you're going to experience in game.
For our testing, we set all the settings to High.  Because of how intense the game is, we tested with 2x anti-aliasing, but with anisotropic filtering disabled, and at a resolution of 1,680 x 1,050.  There is currently no support for anisotropic filtering in the game, but you can still force it from the driver control panel.
      Asus P7P55-M
      Biostar TP55
      ASRock H55M Pro
      Zotac H55-ITX WiFi
      Gigabyte GA-P55M-UD2
      Gigabyte GA-H55M-UD2H
      Asus P7H57D-V Evo
      Zotac H55-ITX WiFi (Core i5-661)
      ASRock P55M Pro
Frames Per Second - higher is better
      Biostar TP55
      Asus P7H57D-V Evo
      ASRock P55M Pro
      Asus P7P55-M
      ASRock H55M Pro
For performance analysis, see
page 9.
Publisher: bitComposer Games
We ran the full
STALKER: Call of Pripyat benchmark, with SSAO set to Low, Tessellation enabled, and Contact Hardening Shadows disabled. We run the game in the Ultra graphical options preset, with the 'Enhan. full dyn. lighting (DX11)' rendering. Of the four runs, we only take the results form the last:
      Asus P7H57D-V Evo
      ASRock H55M Pro
      Zotac H55-ITX WiFi
      Asus P7H57D-V Evo
      ASRock H55M Pro
page 9.
