Power Consumption (Idle and Gaming)
Putting a realistic, repeatable load on a GPU to get a decent idea of its real world power consumption and thermal output has long been something with which we've experimented here at
bit-tech. We've found that synthetic benchmarks such as FurMark thrash the GPU constantly, which simply isn't reflective of how a GPU will be used when gaming.
It's such a hardcore test that any GPU under scrutiny is almost guaranteed to hit its thermal limit; the mark at which the card's firmware will kick in, speeding up the fan to keep the GPU within safe temperature limits. Conversely, simply leaving a game such as Crysis running at a certain point also isn't reflective of real-world use. There's no guarantee that the GPU is being pushed as hard as other titles might push it, and the load will vary between play-throughs.
We used to use the Canyon Flight test of 3DMark 06, as this was a punishing and repeatable test. However, we've now adopted
Unigine's Heaven 3.0 benchmark, as its DirectX 11 features will stress all the parts of a modern GPU. We use the default settings and a resolution of 2,560 x 1,600. We then hit the Benchmark button and watch the power draw from the wall between the grass field scene and the second dragon scene - this is the toughest portion of the test for both Nvidia and AMD hardware.
Nvidia GeForce GTX 660 2GB
Nvidia GeForce GTX 770 3GB
MSI GTX 760 Twin Frozr OC 2GB
AMD Radeon HD 7850 2GB
AMD Radeon HD 7870 2GB
Nvidia GeForce GTX Titan 6GB
Nvidia GeForce GTX 780 3GB
Nvidia GeForce GTX 660 Ti 2GB
Nvidia GeForce GTX 760 2GB
AMD Radeon HD 7970 3GB GHz Edition
AMD Radeon HD 7950 3GB with Boost
Nvidia GeForce GTX 670 2GB
Nvidia GeForce GTX 680 2GB
Nvidia GeForce GTX 690 4GB
AMD Radeon HD 7990 6GB
103
104
105
106
108
108
108
109
110
110
110
111
112
122
127
System Power consumption in Watts
Nvidia GeForce GTX 770 2GB
227
243
244
266
277
286
295
300
314
333
344
352
356
415
470
Thermal Performance (Idle and Gaming)
We also have GPU-Z running in the background, and leave the Unigine benchmark running for ten minutes to record a peak GPU temperature. We present the temperature as a delta T (the difference between the temperature of the GPU and the ambient temperature in our labs).
6
6
7
7
9
10
10
10
10
11
11
11
11
12
14
16
8
10.5
13
15.5
18
Delta T in °C
AMD Radeon HD 7970 3GB GHZ Editon
40
40
41
43
50
53
54
54
54
55
55
57
57
59
59
63
Delta T in °C
*as there's no stock model of the HD 7850 2GB, it is not included in these graphs
