SATA and M.2 Performance
Website: CrystalDiskMark
We test SATA performance with a Samsung SSD 850 Pro, as this is one of the fastest SSDs we've ever tested, and it can saturate the bandwidth of SATA 6Gbps ports.
For M.2 port testing, we use a Samsung SSD 950 Pro. This is rated at 2200MB/sec read and 900MB/sec write speeds - not quite saturating the M.2 PCI-E 3.0 x4 interface but enough to give it a good workout. We use CystalDiskMark's 32QD sequential test.
MSI X99A Gaming Pro Carbon
Asus ROG Strix X99 Gaming
MSI X99A XPower Titanium
Gigabyte GA-X99-Designare EX
200
300
400
500
600
MB/sec
1000
1500
2000
2500
MB/sec
Rightmark Audio Analyzer
Publisher: Rightmark
We use the Playback/Recording test, first adjusting levels so they're within the benchmark parameters and then using 24-bit 192KHz tracks, we connect the line-in to the speaker/line-out jack using a standard 3.5mm audio cable. Following feedback we felt it important to include some results given that on-board audio is a hotly fought-over area with motherboards at the moment.
Gigabyte X99-Gaming 5P
Asus Sabertooth X99
Asus X99-A II
ASRock Fatal1ty X99M Killer
MSI X99A XPower AC
ASRock X99 Extreme 11
Asus X99 Deluxe
EVGA X99 Micro
Asus X99-Pro
Gigabyte X99M-Gaming 5
Gigabyte GA-X99-UD4P
Gigabyte GA-X99-Gaming 5
MSI X99S SLI Plus
MSI X99S MPower
dBA (Higher Is Better)
Asus Sabertooth X99
Asus X99-A II
MSI X99A XPower AC
Asus X99 Deluxe
Asus X99-Pro
EVGA X99 Micro
MSI X99S MPower
MSI X99S SLI Plus
dBA (Lower Is Better)
Asus X99-A II
Asus X99 Deluxe
MSI X99S SLI Plus
Asus X99-Pro
Asus Sabertooth X99
MSI X99A XPower AC
EVGA X99 Micro
MSI X99S MPower
0.005
0.0075
0.01
0.0125
THD Percentage (Lower Is Better)
