PCMark 8 Video Editing
Video Editing v2 Part 2 (Creative 3.0 test suite)
This workload uses
FFmpeg to apply video enhancement filters to a high bitrate H.264 video and then encode it to a format suitable for distribution. The FFmpeg binary used is custom built by Futuremark using a development version of the source available from the project's code repository. The test applies a deshaking filter to a source video at 3,840 x 2160 (4K UHD) before scaling down and outputting at 1,920 x 1,080 (1080p).
Asus Z170i Pro Gaming (4GHz/4.8GHz)
Asus Maximus VIII Hero (4GHz/4.8GHz)
Asus Maximus VIII Gene (4GHz/4.8GHz)
MSI Z170A XPOWER Gaming Titanium Edition (4GHz/4.8GHz)
MSI Z170A Gaming Pro Carbon (4GHz/4.8GHz)
Asus Z170-Deluxe (4GHz/4.8GHz)
Gigabyte Z170X-Gaming 7 (4GHz/4.8GHz)
MSI Z170I Gaming Pro AC (4GHz/4.6GHz)
MSI Z170A Gaming M5 (4GHz/4.6GHz)
MSI Z170A SLI Plus (4GHz/4.7GHz)
Asus Maximus VIII Impact (4GHz/4.9GHz)
Asus Sabertooth Z170 Mark 1 (4GHz/4.8GHz)
Gigabyte Z170MX-Gaming 5 (4GHz/4.8GHz)
Seconds, lower is better
PCMark 8 Photo Editing V2
This workload involves making a series of adjustments to a set of photographs using
ImageMagik - an open-source image processing library to adjust brightness, contrast, saturation and gamma. When a favourable balance is found, the changes are then applied to the rest of the images in the set. TIFF files up to 67MB in size are used.
MSI Z170A Gaming M5 (4GHz/4.8GHz)
SATA and M.2 Performance
Website: CrystalDiskMark
We test the SATA and performance with a Samsung SSD 850 PRO, as this is one of the fastest SSDs we've ever tested, and it can saturate the bandwidth of SATA 6Gbps ports.
For the M.2 port, we've upgraded our old Kingston KyperX Predator SSD to Samsung's SSD 950 Pro M.2 256GB NVMe SSD, which has a claimed throughput of 2,200MB/sec read and 900MB/sec write, and also updated to a newer version of CrystalDiskMark. We'll be adding to this graph over time to include more results.
MSI Z170A Gaming M5 (Intel SATA 6Gbps)
Asus Sabertooth Z170 Mark 1 (Intel SATA 6Gbps)
Gigabyte Z170X-Gaming 7 (Intel SATA 6Gbps)
Asus Maximus VIII Hero (Intel SATA 6Gbps)
Asus Z170i Pro Gaming (Intel SATA 6Gbps)
MSI Z170A Gaming Pro Carbon (Intel SATA 6Gbps)
Asus Maximus VIII Gene (Intel SATA 6Gbps)
MSI Z170A XPOWER Gaming Titanium Edition ( (Intel SATA 6Gbps)
Asus Z170-Deluxe (Intel SATA 6Gbps)
MSI Z170A SLI Plus (Intel SATA 6Gbps)
MSI Z170I Gaming Pro AC (Intel SATA 6Gbps)
Gigabyte Z170MX-Gaming 5 (Intel SATA 6Gbps)
Asus Maximus VIII Impact (Intel SATA 6Gbps)
Asus Sabertooth Z170 Mark 1 (ASMedia 6Gbps)
Asus Z170-Deluxe (ASMedia 6Gbps)
MSI Z170A XPOWER Gaming Titanium Edition (ASMedia 6Gbps)
Gigabyte Z170X-Gaming 7 (ASMedia 6Gbps)
MB/sec, higher is better
MSI Z170A SLI Plus
1000
1500
2000
2500
