PCMark 8 Video Editing
Video Editing Part 2 V2 (Creative 3.0 test suite)
This workload uses
FFmpeg to apply video enhancement filters to a high bitrate H.264 video and then encode it to a format suitable for distribution. The FFmpeg binary used is custom-built by Futuremark using a development version of the source available from the project's code repository. The test applies a deshaking filter to a source video at 3,840 x 2160 (4K UHD) before scaling down and outputting at 1,920 x 1,080 (1080p). It's worth noting that FFmpeg does not benefit from more than two CPU cores.
Gigabyte Aorus Z270X-Gaming 7 (4.2GHz/5GHz)
Asus ROG Strix Z270F Gaming (4.2GHz/5GHz)
MSI Z270 XPower Gaming Titanium (4.2GHz/5GHz)
MSI Z270 Gaming Pro Carbon (4.2GHz/5GHz)
Seconds (lower is better)
PCMark 8 Photo Editing V2
This workload involves making a series of adjustments to a set of photographs using
ImageMagik - an open-source image processing library - to adjust brightness, contrast, saturation and gamma. When a favourable balance is found, the changes are then applied to the rest of the images in the set. TIFF files up to 67MB in size are used.
