MSI K9A Platinum
January 23, 2007 | 15:27
Tags: #64 #am2 #athlon #crossfire #ddr2 #firewire #gpu #multi #pci #pci-express #rd580 #sb600 #usb #x16
Companies: #amd #msi
Testing Methods:
With the exception of SiSoft Sandra, all of our benchmarks have been engineered to give you numbers that you are likely to find useful when actually using the products we have evaluated in the real world.
We are also focusing a lot more of our time on evaluating the stability of the motherboards (and platforms) using a stress test designed to highlight any of the potential weaknesses that the product may have. That involves a gradually increasing amount of stress starting with Prime95 and expanding to IOMeter and an endless loop of Far Cry if all is well. This is to ensure that all parts of the system are stressed simultaneously over a period of time.
We believe that the consumer is never likely to subject their platform to this level of stress and we are not expecting every product to complete an entire extended stress test. However, most poorly engineered products fail within the first couple of hours, or even minutes, allowing us to make a conscious decision on whether a motherboard (or platform) is worth your money, regardless of how well it performs in our benchmarks.
MSI K9A Platinum Test Setup
Test Setup:
AMD Athlon 64 FX-62 (operating at 2800MHz - 14x200); 2 x 1GB Corsair XMS2-8500C5 (running at DDR2-800 in dual channel with 3.0-3-3-9-1T timings at 2.3V); BFG Tech GeForce 7900 GTX OC video card (operating at 670/1640MHz); Sapphire X1900XTX in CrossFire; Seagate 7200.9 200GB 7,200RPM SATA 3Gbps hard disk drive; OCZ GameXStream 700W power supply unit; Windows XP Professional Service Pack 2; DirectX 9.0c; NVIDIA Forceware 93.71 WHQL; ATI Catalyst 6.10 WHQL.
Motherboard List:
  • MSI K9A Platinum (AMD 580X);
  • Sapphire PURE CrossFire PC-AM2RD580 (AMD 580X);
  • MSI K9N SLI Platinum (nForce 570 SLI);
