Crysis 2
Publisher: EA
From our
Crysis 2  Review:
When we played Crysis 2 on the consoles, we honestly could have taken or left it. Only on the PC do we feel comfortable recommending and replaying Crytek’s best game yet – and its first chance of matching technical prowess with good game design. '
Crysis 2 is incredibly taxing on all components in a system, from CPU to GPU, so we've chosen to test without AA to generate meaningful and playable frame rates above 1,920 x 1,080. Otherwise, we run the game at its highest 'Ultra' settings and with both the
DX11 tessellation pack and high-resolution texture packs installed.
We use the
Adrenaline Crysis 2 Benchmark Tool to automate our testing, but capture results in-game using FRAPs as the tool's ability to record minimum frame-rates is inconsistent.
We test using the Times Square time demo, recording minimum and average frame rates from frame 1000 to frame 4900 of the time demo, with the result being the average over 3 runs.
        Nvidia GeForce GTX 690 4GB
        AMD Radeon HD 7970 3GB GHz Edition
        Nvidia GeForce GTX 680 2GB
        Nvidia GeForce GTX 670 2GB
        AMD Radeon HD 7950 3GB with Boost
        Nvidia GeForce GTX 580 1.5GB
        Nvidia GeForce GTX 660 Ti 2GB
        AMD Radeon HD 7870 2GB
        Nvidia GeForce GTX 570 1280MB
        Nvidia GeForce GTX 660 2GB
        AMD Radeon HD 7850 2GB
        Nvidia GeForce GTX 560 Ti 1GB
         AMD Radeon HD 6970 2GB
        Nvidia GeForce GTX 460 1GB
        AMD Radeon HD 6950 1GB
        AMD Radeon HD 6870 1GB
          20
          30
          40
          50
          60
          70
          80
          90
    Frames Per Second
Frames Per Second
Frames Per Second
Read our
performance analysis.
