Power Consumption (Idle and Gaming)
Putting a realistic, repeatable load on a GPU to get a decent idea of its real world power consumption and thermal output has long been something with which we've experimented here at
bit-tech. We've found that synthetic benchmarks such as FurMark thrash the GPU constantly, which simply isn't reflective of how a GPU will be used when gaming.
It's such a hardcore test that any GPU under scrutiny is almost guaranteed to hit its thermal limit; the mark at which the card's firmware will kick in, speeding up the fan to keep the GPU within safe temperature limits. Conversely, simply leaving a game such as Crysis running at a certain point also isn't reflective of real-world use. There's no guarantee that the GPU is being pushed as hard as other titles might push it, and the load will vary between play-throughs.
We used to use the Canyon Flight test of 3DMark 06, as this was a punishing and repeatable test. However, we've now adopted
Unigine's Heaven 2.5 benchmark, as its DirectX 11 features will stress all the parts of a modern GPU. We use the default settings and a resolution of 1,920 x 1,080. We also check that 4x AA and 4x AF are enabled and that tessellation is set to Standard. We then hit the Benchmark button and watch the power draw from the wall between the grass field scene and the second dragon scene - this is the toughest portion of the test for both Nvidia and AMD hardware.
We also have GPU-Z running in the background, and leave the Unigine benchmark running for ten minutes to record a peak GPU temperature. We present the temperature as a delta T (the difference between the temperature of the GPU and the ambient temperature in our labs).
        AMD Radeon HD 7750 1GB
        AMD Radeon HD 7770 1GB
        AMD Radeon HD 7870 2GB
        Nvidia GeForce GTX 560 1GB
        Nvidia GeForce GTX 680 2GB
        Nvidia GeForce GTX 560 Ti 1GB (Third party cooler)
        AMD Radeon HD 7950 3GB
        AMD Radeon HD 7970 3GB
        AMD Radeon HD 6870 1GB
        AMD Radeon HD 6850 1GB
        AMD Radeon HD 5770 1GB
        Nvidia GeForce GTX 550 Ti 1GB
        AMD Radeon HD 6950 2GB
        AMD Radeon HD 6950 1GB
        AMD Radeon HD 6970 2GB
        Nvidia GeForce GTX 570 1280MB
        Nvidia GeForce GTX 580 1.5GB
        Nvidia GeForce GTX 560 Ti 448 (Third party cooler)
        AMD Radeon HD 6990 4GB
        Nvidia GeForce GTX 590 3GB
            81
            82
            87
            88
            89
            89
            89
            90
            91
            91
            92
            92
            94
            94
            95
            102
            106
            108
            113
            134
    System Power consumption in Watts
        Nvidia GeForce GTX 550 Ti 1GB (custom PCB)
            121
            142
            160
            175
            188
            193
            193
            210
            210
            215
            227
            245
            246
            253
            253
            256
            284
            293
            414
            427
Thermal Performance
        AMD Radeon HD 7770 4GB
        Nvidia GeForce GTX 550 Ti 1GB (Custom cooler)
        AMD Radeon HD 7750 4GB
        AMD Radeon HD 5770 4GB
            6
            10
            10
            10
            10
            10
            11
            11
            11
            12
            13
            14
            15
            16
            17
            17
            18
            18
            22
            22
    Delta T in °C
        Nvidia GeForce GTX 550 Ti 1GB (custom cooler)
            31
            32
            40
            40
            42
            44
            47
            50
            52
            53
            53
            54
            54
            54
            56
            57
            58
            63
            64
            65
    Delta T in °C
Read our
performance analysis.
