Nvidia GeForce GTX 690 4GB Review
Written by Mike Jennings
June 13, 2012 | 07:34
Tags: #best-graphics-card #dual-gpu #dual-gpu-graphics-card #fastest-graphics-card #gtx-690
Companies: #nvidia
How We Tested
As always, we did our best to deliver a clean set of benchmarks, with each test repeated three times, and an average of those results is what we’re reporting here. In the rare case where performance was inconsistent, we continued repeating the test until we obtained three results that were consistent.
The tests performed are a mixture of custom in-game time demos and manually-played sections, using FRAPS to record the average and minimum frame rates. We strive to not only record real-world performance you will actually see, but also present the results in a manner that is easy to digest.
Nvidia GeForce GTX 690 4GB Review Test Setup
Test System
  • Intel Core i5-2500K (operating at 3.3GHz – 33 x 100MHz)
  • Asus P8P67 motherboard (Intel P67)
  • 2 x 2GB Corsair 1,600MHz DDR3 memory
  • PC Power & Cooling Silencer 750W PSU
  • Windows 7 Home Premium 64bit
AMD graphics cards
  • AMD Radeon HD 7870 2GB (1,000MHz GPU, 4.8GHz memory) (Release driver)
  • AMD Radeon HD 7850 2GB (860MHz GPU, 4.8GHz memory) (Release driver)
  • AMD Radeon HD 7950 3GB (800MHz GPU, 5GHz memory) (Release driver)
  • AMD Radeon HD 7970 3GB (925MHz GPU, 5.5GHz memory) (Release Driver)
  • AMD Radeon HD 7770 1GB(1,000MHz GPU, 4.5GHz memory) ( (Release driver)
  • AMD Radeon HD 7750 1GB(800MHz GPU, 4.5GHz memory) (Release driver)
  • AMD Radeon HD 6990 4GB (2 x 830MHz GPUs, 2 x 5GHz memory) (Catalyst 11.12)
  • AMD Radeon HD 6970 2GB (840MHz GPU, 4.2GHz memory) (Catalyst 11.12)
  • AMD Radeon HD 6950 2GB (800MHz GPU, 5GHz memory) (Catalyst 11.12)
  • AMD Radeon HD 6950 1GB (800MHz GPU, 5GHz memory) (Catalyst 11.12)
  • AMD Radeon HD 6870 1GB (900MHz GPU, 4.2GHz memory) (Catalyst 11.12)
  • AMD Radeon HD 6850 1GB (725MHz GPU, 4GHz memory) (Catalyst 11.12)
Nvidia graphics cards
  • Nvidia GeForce GTX 690 4GB (915MHz, boosting to 1,084MHz, 6GHz memory) (Release Driver 301.33)
  • Nvidia GeForce GTX 670 2GB (915MHz, boosting to 1,084MHz, 6GHz memory) (Release Driver 301.33)
  • Nvidia GeForce GTX 680 2GB (1,006MHz, boosting to 1,110MHz, 6GHz memory) (Release Driver 300.99)
  • Nvidia GeForce GTX 590 3GB (2 x 607MHz GPUs, 1,214MHz stream processors, 4,114MHz memory) (GeForce 290.36 beta)
  • Nvidia GeForce GTX 580 1.5GB (772MHz GPU, 1,544MHz stream processors, 4,080MHz memory) (GeForce 285.62 WHQL)
  • Nvidia GeForce GTX 570 1280MB (732MHz GPU, 1,464MHz stream processors, 3,800MHz memory) (GeForce 285.62 WHQL)
  • Nvidia GeForce GTX 560 Ti 448 (732MHz GPU, 1,464MHz stream processors, 3,800MHz memory) (GeForce 285.62 WHQL)
  • Nvidia GeForce GTX 560 Ti 1GB (820MHz GPU, 1,640MHz stream processors, 4,000MHz memory) (GeForce 285.62 WHQL)
  • Nvidia GeForce GTX 560 1GB (810Mhz GPU, 1,620MHz stream processors, 4,000MHz memory) (GeForce 285.62 WHQL)
*GeForce cards have been retested in Skyrim with Geforce 290.16 to provide better direct comparison.
Games Tested
  • Arma II: Operation Arrowhead (DX9)
  • Battlefield 3 (DX11)
  • Dirt 3 (DX11)
  • The Elder Scrolls V: Skyrim (DX9)
