Overclockers UK Titan Katana Ryzen Review
Written by Antony Leather
June 14, 2017 | 17:49
Tags: #best-gaming-pc #gaming-pc #overclocked-pc #overclockers-uk-pc
Companies: #amd #overclockers-uk
PCMark 8 Video Editing
Video Editing V2 Part 2 (Creative 3.0 test suite)
Overclockers UK Titan Katana Ryzen Review Overclockers UK Titan Katana Ryzen Review - Content Creation
This workload uses FFmpeg to apply video enhancement filters to a high bitrate H.264 video and then encode it to a format suitable for distribution. The FFmpeg binary used is custom-built by Futuremark using a development version of the source available from the project's code repository. The test applies a deshaking filter to a source video at 3,840 x 2160 (4K UHD) before scaling down and outputting at 1,920 x 1,080 (1080p).
PCMark 8 Video Editing Part 2 V2
Completion time
  • Intel Core i5-7600K (5.1GHz)
  • Intel Core i7-7700K (5GHz)
  • Overclockers UK Titan Osprey
  • Intel Core i7-6700K (4.8GHz)
  • Intel Core i5-6600K (4.8GHz)
  • The PC Customiser Venom VR Powered by Gigabyte
  • DinoPC C3 Mod Gaming PC
  • Corsair One Pro
  • Intel Core i7-6850K (4.4GHz)
  • Overclockers UK Titan Katana Ryzen
  • PC Specialist Magma Zen
    • 92
    • 94
    • 96
    • 97
    • 98
    • 98
    • 102
    • 104
    • 105
    • 112
    • 113
    • 115
    • 123
    • 130
    • 139
    • 154
50
75
100
125
150
Seconds (lower is better)
  • Time
PCMark 8 Photo Editing V2
This workload involves making a series of adjustments to a set of photographs using ImageMagik - an open-source image processing library to adjust brightness, contrast, saturation and gamma. When a favourable balance is found, the changes are then applied to the rest of the images in the set. TIFF files up to 67MB in size are used.
Load image matrix + adjusting times
  • Corsair One Pro
    • 22
    • 26
    • 29
    • 29
    • 29
    • 30
    • 31
    • 31
    • 31
    • 32
    • 32
    • 33
    • 33
    • 33
    • 34
    • 37
20
30
40
  • Time
HandBrake Video Transcode
We've added HandBrake to our list of content creation tests, as PCMark 8's video encoding test isn't able to make use of more than two threads and as such doesn't give a true representation of video encoding/editing workloads and performance. As this task is a key reason for opting for a powerful system, we've added a simple encoding test using the freely available HandBrake software, which converts a 60-second, 400MB, 4K, MKV video sample to a high quality 1080p MP4 file using the available presets. Our results show much better scaling with increasing threads, which is more indicative of high-performance video editing suites, albeit without any GPU acceleration.
HandBrake Video Transcoding
4K MKV to high quality 1080p MP4 encode
  • Intel Core i7-6900K (4.2GHz)
  • AMD Ryzen 7 1700 (4.05GHz)
  • AMD Ryzen 7 1800X (4GHz)
  • AMD Ryzen 7 1800X
  • AMD Ryzen 7 1700
    • 74
    • 75
    • 76
    • 79
    • 83
    • 84
    • 101
50
75
100
Time
  • Time
