July 23, 2021 | 14:15
Companies: #amd #corsair #cyberpower #cyberpowerpc #ek-water-blocks #lian-li #msi #nvidia #seagate #western-digital
While Cyberpower has done a solid job on most of the component selection, we're not as impressed with the fit and finish.
Heading inside the case is where we noticed a couple of issues. The first and possibly the easiest to fix is the lack of one of the motherboard EPS connectors being plugged in. This didn't cause any stability during benchmarking, but as a general rule of thumb, motherboard manufacturers recommend plugging both in, if available, which the supplied Corsair HX850 supports.
A large scratch on the upper part of the chassis was also noted, but this may well be a one-off issue. Lastly, highlighting attention to detail, we noticed some grime inside the block along with a fingerprint mark that's not super-obvious, but in a well-lit room or when the RGB turns on it's easy to see. There also seems to be no way to fix this without dismantling the watercooling loop as it's internal and there seems to be no way to partially open up the GPU block. We've added close-ups of these two issues below.
In summary, Cyberpower has chosen some really top-end hardware to showcase the best of what 2021 has to offer the PC enthusiast. More care in terms of fit and finish, plus a quieter noise profile, would elevate this rig from average to potentially very good.
