Dino PC Primal GSX Review
Written by Antony Leather
February 10, 2016 | 08:48
Tags: #best-gaming-pc #overclocked-pc #overclockers-uk-pc #z170-system
Companies: #dino-pc
PCMark 8 Video Editing
Video Editing V2 Part 2 (Creative 3.0 test suite)
This workload uses FFmpeg to apply video enhancement filters to a high bitrate H.264 video and then encode it to a format suitable for distribution. The FFmpeg binary used is custom built by Futuremark using a development version of the source available from the project's code repository. The test applies a deshaking filter to a source video at 3,840 x 2160 (4K UHD) before scaling down and outputting at 1,920 x 1,080 (1080p).
PCMark 8 4K Video Editing
Part 2 test
  • DinoPC Troodon
  • PC Specialist Vitrum
  • Dino PC GSX
  • Utopia Pandora
  • Cyberpower Infinity X55 Pro GT
  • Overclockers UK Infin8 Nebula
  • PC Specialist Apollo 703
  • Intel Core i7-4790K (4GHz/4.8GHz)
  • Overclockers UK Titan Wave
  • Intel Core i7-5930K (3.5GHz/4.55GHz)
  • CCL Elite Strix 100
  • AMD FX-8350 (4GHz/4.6GHz)
    • 100
    • 0
    • 104
    • 0
    • 105
    • 0
    • 106
    • 0
    • 107
    • 0
    • 107
    • 0
    • 111
    • 0
    • 112
    • 107
    • 127
    • 0
    • 130
    • 106
    • 136
    • 0
    • 542
    • 472
200
300
400
500
600
Seconds, lower is better
  • Stock
  • Overclocked
PCMark 8 Photo Editing V2
This workload involves making a series of adjustments to a set of photographs using ImageMagik - an open-source image processing library to adjust brightness, contrast, saturation and gamma. When a favourable balance is found, the changes are then applied to the rest of the images in the set. TIFF files up to 67MB in size are used.
Load image matrix + adjusting times
  • Dino PC GSX
  • DinoPC Troodon
  • Utopia Pandora
    • 28
    • 0
    • 31
    • 0
    • 31
    • 25
    • 32
    • 0
    • 33
    • 0
    • 33
    • 0
    • 33
    • 0
    • 37
    • 0
    • 37
    • 0
    • 38
    • 36
    • 57
    • 0
    • 64
    • 53
20
30
40
50
60
70
  • Stock
  • Overclocked
