PCMark 8 Video Editing
Video Editing V2 Part 2 (Creative 3.0 test suite)
This workload uses
FFmpeg to apply video enhancement filters to a high bitrate H.264 video and then encode it to a format suitable for distribution. The FFmpeg binary used is custom-built by Futuremark using a development version of the source available from the project's code repository. The test applies a deshaking filter to a source video at 3,840 x 2160 (4K UHD) before scaling down and outputting at 1,920 x 1,080 (1080p).
        PC Specialist Define X1
        Overclockers UK Titan Agent 47
        Dino PC GSX
        Fresh Tech Solutions Ultimate Collection 6700K
        DinoPC Troodon
        Intel Core i7-5930K (3.5GHz/4.55GHz)
        Core i7-6700K (4GHz/4.8GHz)
        Fresh Tech Solutions 6600K Falcon R
        Utopia Pandora
        Overclockers UK Titan Bayonet
        Intel Core i7-6950X (3GHz/4.4GHz)
        PC Specialist Vitrum
        Overclockers UK Titan Wave
        Overclockers UK Infin8 Nebula
        Scan 3XS Z170 Performance GTK4
        Cyberpower Infinity X55 Pro GT
        PC Specialist Apollo 703
        Intel Core i7-4790K (4GHz/4.8GHz)
        CCL Elite Strix 100
        AMD FX-8350 (4GHz/4.6GHz)
Seconds, lower is better
PCMark 8 Photo Editing V2
This workload involves making a series of adjustments to a set of photographs using
ImageMagik - an open-source image processing library to adjust brightness, contrast, saturation and gamma. When a favourable balance is found, the changes are then applied to the rest of the images in the set. TIFF files up to 67MB in size are used.
        Dino PC GSX
        DinoPC Troodon
        Utopia Pandora
        CCL Elite Strix 100
