PCMark 8 Video Editing
Video Editing V2 Part 2 (Creative 3.0 test suite)
This workload uses
FFmpeg to apply video enhancement filters to a high bitrate H.264 video and then encode it to a format suitable for distribution. The FFmpeg binary used is custom-built by Futuremark using a development version of the source available from the project's code repository. The test applies a deshaking filter to a source video at 3,840 x 2160 (4K UHD) before scaling down and outputting at 1,920 x 1,080 (1080p).
        DinoPC Troodon
        Scan 3XS Z170 Performance GTK4
        PC Specialist Define X1
        Overclockers UK Titan Agent 47
        Fresh Tech Solutions 6600K Falcon R
        PC Specialist Vitrum
        Dino PC GSX
        Fresh Tech Solutions Ultimate Collection 6700K
        Utopia Pandora
        Cyberpower Infinity X55 Pro GT
        Overclockers UK Infin8 Nebula
        PC Specialist Apollo 703
        Intel Core i7-6700K (4GHz/4.8GHz)
        Intel Core i7-4790K (4GHz/4.8GHz)
        Overclockers UK Titan Wave
        Intel Core i7-6950X (3GHz/4.4GHz)
        Intel Core i7-5930K (3.5GHz/4.55GHz)
        CCL Elite Strix 100
        AMD FX-8350 (4GHz/4.6GHz)
          200
          300
          400
          500
          600
    Seconds, lower is better
PCMark 8 Photo Editing V2
This workload involves making a series of adjustments to a set of photographs using
ImageMagik - an open-source image processing library to adjust brightness, contrast, saturation and gamma. When a favourable balance is found, the changes are then applied to the rest of the images in the set. TIFF files up to 67MB in size are used.
        Dino PC GSX
        DinoPC Troodon
        Utopia Pandora
        CCL Elite Strix 100
