Written by Matthew Lambert
May 23, 2018 | 17:00
Tags: #80-plus-gold #power-supply #psu #semi-modular #silverstone
Companies: #silverstone
        For these tests, we take a reading of the voltage output of each PSU's 12V rail (or rails, if it uses a multi-rail design). This is done at three load levels: low, medium, and high, which vary based on the wattage of PSU being tested. We are looking for results as close to 12V as possible. Higher loads are more likely to highlight any instabilities. Any output that falls outside of Intel's specifications is considered a fail. You should avoid any PSU that fails this testing.
