Testing Methods
Any device connected to a Gigabit LAN will have maximum read and write speeds of 125MB/sec. However, just as the controller chip on an SSD has a huge effect on the drive's speed, the same is also true for NAS boxes. As they’ll be used for storing lots of tiny files, as well as large video files, we use two 5GB folders (one full of small files, and the other packed with large video files), in order to gauge the flexibility of each box.
Our test involves writing to each NAS box separately, and then reading from them. The small file folder is filled with 10,000 files that included photos, Word documents and short videos, while the large file folder comprises three 1.7GB videos.
We install the same 1TB Samsung SpinPoint F3 hard drive in each NAS box, which was connect to a Netgear Gigabit Ethernet switch for all of the read and write tests. We then record the time it takes to transfer each folder in seconds, and use this result to work out the average transfer rate. You can see the speed test results in the graphs below.
To read and write from the NAS box, we use a PC built around an Asus P7H55-M motherboard, 4GB of Crucial DDR3 RAM and an Intel Pentium G6950 CPU overclocked to 4GHz. To eliminate any reading or writing bottleneck at the PC end, we also use a Corsair X128 SSD.
Once a NAS box is up and running, we then also try out all of the features, such as shared folders, iTunes servers, iSCSI and Bit-Torrent clients, in order to see how easy they are to set up and use on a regular basis. In addition, we also take noise and hard drive temperature into consideration, as well as the build quality.
Performance
        Thecus N2200XXX
        QNAP 219P II
        Synology DS211+
        Synology DiskStation DS211j
        QNAP TS-219P Turbo NAS
        LG N2B1D
        Synology DS210+
        QNAP TS-210 Turbo NAS
        Synology USB Station 2
        ZyXEL NSA-220 Plus
        Icy Box IB-NAS3221
        Xtreamer eTRAYz
            92.3
            86.0
            81.9
            64.1
            43.5
            38.6
            37.0
            35.4
            19.0
            16.5
            15.5
            10.0
    MB/sec Higher is Better
        Thecus N2200XXX
        QNAP TS-219P II
        Synology DS210+
        Synology DS211+
        LG N2B1D
        Xtreamer eTRAYz
        Icy Box IB-NAS3221
        ZyXEL NSA-220 Plus
            99.6
            66.8
            51.0
            45.0
            35.1
            27.0
            22.8
            18.2
            18.0
            13.3
            12.7
          9.0
        Synology DS211+
        Synology DS210+
        QNAP 219P II
        Thecus N2200XXX
        LG N2B1D
        Icy Box IB-NAS3221
        ZyXEL NSA-220 Plus
        Xtreamer eTRAYz
            46.3
            24.2
            22.0
            21.1
            20.0
            17.0
            16.3
            15.5
            15.0
            9.9
            9.8
          1.0
        Synology DS211+
        Synology DS210+
        Thecus N2200XXX
        QNAP TS-219P II
        LG N2B1D
        Icy Box IB-NAS3221
        ZyXEL NSA-220 Plus
        Xtreamer eTRAYz
            36.9
            27.0
            24.5
            22.9
            19.9
            17.6
            14.2
            12.0
            10.3
            6.4
            4.5
          1.0
Read our
performance analysis.
