Cooling Performance
As we mentioned in the review, our test graphics card wouldn't quite fit in the DS380 so we used a GeForce GTX 750Ti instead. In addition, we had to use an SFX PSU instead of our usual ATX model - this was graciously provided by SilverStone in the form of its SST-ST45SF-G PSU. This means that neither the CPU or GPU delta T's are directly comparable to our other cases on test.  However we've included the CPU delta T graph as a rough guide on how well the case deals with an overclocked processor. We could have removed the drive bay and installed our usual mini-ITX case test graphics card but then this would skew results further and ignore the impact of the hot swap drive mount on cooling.
Our mini-ITX test kit includes:
- CPU: Intel Core i5-2500K overclocked to 4.3GHz using a vcore of 1.3V.
    - Motherboard: Asus P8Z77-I Deluxe
    - RAM: 4GB Kingston DDR3 1600MHz memory
    - PSU: Enermax Eco 82+ 620W PSU
   - CPU cooler: Zalman CNPS 8900 low-profile cooler
While some cases can house larger coolers, for the results to be comparable, we needed to pick a cooler that was going to fit in as many cases as possible. We therefore opted for a low-profile cooler. This will give a good idea of how well the case is able to remove heat from the system - our primary concern in case testing - although you can probably expect to achieve better results by using a larger cooler if the case in question supports it.
The system was loaded using Prime95 and Unigine's Heaven benchmark. We used Realtemp and GPU-Z to monitor the temperatures, taking the maximum values when the readings had plateaued.
        SilverStone Raven RVZ01
        Silverstone Sugo SG08 (max speed)
        BitFenix Prodigy
        Silverstone Sugo SG08 (min speed)
        Silverstone FT03-Mini
        Fractal Design Node 304 (max speed)
        Cooler Master Elite 130 Advanced
        Lian Li PC-TU200
        Corsair Obsidian 250D
        Lian Li PC-V360
        Lian Li Lian Li PC-Q28
        SilverStone DS380 (different GPU)
        In-Win 901 (Zalman ZM-F2 92mm + Noctua NF-F12 120mm)
        Lian Li PC-V358
        EVGA Hadron Air
        BitFenix Phenom
        Cooler Master Elite 120 Advanced
        Antec ISK600
        Fractal Design Node 304 (min speed)
        In-Win 901 (no fans)
          20
          30
          40
          50
          60
          70
          80
    °C, lower is better
