Vadim Fusion LQX Intel-775G2
September 13, 2007 | 13:48
Tags: #airbrush #case #computer #fusion #lady #orange #overclock #q6600
Companies: #vadim
Audio Performance
The audio performance tests we done using Audio Rightmark 6.0.5 and a 3.5mm gold plated, oxygen free stereo loop back cable between stereo out and microphone input. Results were taken at the DVD sample rate of 16-bit/48KHz and High Definition 24-bit/96KHz.
What we're looking for:
  • Noise Level: A higher negative is better. This is usually viewed in relation to a signal level which provides a signal to noise ratio. As you get closer to zero there's more noise and lesser audio fidelity.
  • Frequency Response: Two values listing how close to the lower higher frequencies the codec can reach. If it hits them perfectly it'll display a 0, 0.
  • Dynamic Range: The difference between the loudest and quietest sounds the codec can make before it distorts them. The larger the gap, the better.
  • THD and IMD percentage: Closer to zero is better. THD and IMD are best looked at together, where as if you have a lot of THD and not much IMD, then it'll offer a warmer accurate sound. High THD and IMD provides a warm, inaccurate sound, low THD and high IMD gives a cold inaccurate sound and finally low THD and IMD gives a cold accurate sound.
  • IMD = intermodulation distortion and is a fancy way of saying conversion interpolation, which is a basic detection of the quality loss after an analogue to digital then digital to analogue conversion. By comparing it to a highly compressed source it shows up problems with the codec and converters.
  • THD = total harmonic distortion, which shows up unwanted harmonics; integer multiples of the original component sound that can be second, third, fourth degrees or overtones for example.
  • Stereo Crosstalk: where the stereo channels "talk" to each other and interact. Ideally you want them entirely separate, unmixed or echoed in either channel, so a higher negative a result as possible is preferred.
16-bit / 48KHz
Vadim Fusion LQX Intel-775G2 Subsystem Testing: Audio Performance
Click for Large Images
Vadim Fusion LQX Intel-775G2 Subsystem Testing: Audio Performance Vadim Fusion LQX Intel-775G2 Subsystem Testing: Audio Performance Vadim Fusion LQX Intel-775G2 Subsystem Testing: Audio Performance
Crosstalk, Dynamic Range and Frequency Response
Intermodulation Distortion, Intermodulation Distortion Swept and Noise Level
Total Harmonic Distortion
24-bit / 96KHz
The results of the Creative X-Fi ExtremeGamer Fatal1ty Edition are a whole lot better compared to the trouble we've had getting RMAA 6.05 to work in the past. As a gaming PC this is the card of choice to have with 64MB of onboard memory and advanced EAX HD. The Xonar has a slightly better signal to noise ratio at 16-bit/48KHz and is significantly better quality than the X-Fi at 24-bit/96KHz, which doesn't have quite as advanced DACs and uses electrolytic capacitors.
