ViewSonic VX2435wm 24" widescreen
June 24, 2007 | 11:04
Manufacturer: ViewSonic
UK Price (as reviewed): £460.78 (inc. VAT)
US Price (as reviewed): $649.95 (ex. Tax)
In many regards ViewSonic's monitors have a great pedigree, but it has always suffered in the knowledge that the likes of Samsung, Dell and BenQ seem to punch just a little too high for comfort. This has often resulted in a somewhat lukewarm response for its products.
But, that's no reason to dismiss ViewSonic out of hand and this 24 inch widescreen LCD has all the raw attributes to be a very good monitor.
As with all monitors of this size the VX2435wm has a 1920x1200 native resolution, which provides support for 1080p content and allows for two A4 pages to be set side by side at 100 percent zoom.
It uses an 8-bit P-MVA panel, sports a 1000:1 contrast ratio, claims an 8ms grey-to-grey response time and an excellent 500cd/m² brightness rating. Connectivity wise there is an HDCP compliant HDMI port, Component, S-Video, Composite, D-Sub and finally a 3.5mm audio jack for the internal speakers.
You'll notice one thing missing in this list, DVI. Thus, in the box the VX2435wm comes with a DVI to HDMI cable for a digital connection. In one sense it's quite a smart move, HDMI is obviously a smaller connection though the general trend recently has been for monitors of this size to have an HDMI port in addition to the usual DVI and D-Sub ports.
Given that this monitor has been marketed as an all round workhorse, providing connectivity for your PC, Xbox 360, PS3 and whatever else, then the absence of a DVI port is rather curious. How, for example, would you connect a PC and a PS3 at the same time? With difficulty would be the answer, or perhaps by using an HDMI switcher box such as the Belkin Pure AV HDMI 3-to-1. Of course, for the extra money spent on a switcher one could just as easily spend more on a monitor with a separate HDMI port; the awesome BenQ FP241W springs to mind.
Connection considerations aside on paper this a very well specified monitor. Response time is within expectations, but the 500cd/m² brightness is excellent and while the 1000:1 Contrast Ratio may not seem astounding it's a genuine figure and not enhanced by any "Dynamic" processing - the value of which is severely debatable. The lack of any USB hub is little disappointing, but not critically so.
Specification Summary
  • 24" (wide) viewable area
  • 1920x1200 native resolution
  • 8ms response time (grey-to-grey)
  • 500cd/m²
  • Contrast ratio: 1000:1
  • HDMI -DVI; VGA; Component
  • Price: Around £460 (inc. VAT)
null
