X99 Motherboard Group Test: Asus, EVGA, Gigabyte and MSI
Written by Antony Leather
September 9, 2014 | 18:50
Tags: #best-2011-motherboard #best-haswell-e-motherboard #haswell-e #lga2011-v3 #x99
Companies: #asus #bit-tech #evga #gigabyte #msi
Terragen 3
Website:Terragen 3
Planetside Software’s Terragen 2 is a highly realistic landscape generator used to create background images in films and games such as Star Trek: Nemesis, Stealth and The Imaginarium of Dr. Parnassus. Our script renders a single frame of a snowy mountain scene at 640 x 480 on all the available CPU execution units.
Terragen 3
Snowy scene render time
  • Asus X99 Deluxe (3GHz/4.25GHz)
  • Gigabyte GA-X99-Gaming 5 (3GHz/4.2GHz)
  • MSI X99S SLI Plus (3GHz/4.3GHz)
  • EVGA X99 Micro (3GHz/4.2GHz)
    • 321
    • 277
    • 330
    • 271
    • 335
    • 267
    • 338
    • 269
100
150
200
250
300
350
Seconds, lower is better
  • Stock
  • Overclocked
Cinebench R15 64-bit
Website: www.maxon.net
Cinebench uses Maxon's Cinema 4D engine to render a photo-realistic scene of some shiny balls and weird things (we miss the motorbike). The scene is highly complex, with reflections, ambient occlusion and procedural shaders so it gives a CPU a tough workout.
As Cinema 4D is a real-world application - used on films such as Spider-Man and Star Wars - Cinebench can be viewed as a real-world benchmark.
Cinebench R15
64-bit, CPU test
    • 1403
    • 1684
    • 1376
    • 1612
    • 1330
    • 1698
    • 1312
    • 1674
500
750
1000
1250
1500
1750
Score, higher is better
  • Stock Speed
  • Overclocked
Power consumption
For the power consumption tests, we measure via a power meter at the wall, so the numbers below are of total system power draw from the mains, not the power consumption of a CPU itself. Measuring the power draw of any individual component in a PC is tricky to impossible to acheive. We use Prime95's smallFFT test to put the CPU under 100 load, while idle power results were taken with the PC sitting at a Windows Aero-enabled desktop.
Power Consumption (Idle)
Windows Aero enabled
  • Gigabyte GA-X99-Gaming 5 (2,133MHz RAM)
  • MSI X99S SLI Plus (2,133MHz RAM)
  • EVGA X99 Micro (2,133MHz RAM)
  • Asus X99 Deluxe (2,133MHz RAM)
    • 70
    • 0
    • 86
    • 100
    • 86
    • 0
    • 89
    • 0
    • 90
    • 97
    • 90
    • 128
    • 106
    • 0
    • 127
    • 151
50
75
100
125
150
Watts, lower is better
  • Stock Speed
  • Overclocked
Power Consumption (Load)
    • 233
    • 465
    • 236
    • 422
    • 243
    • 397
    • 314
    • 478
200
300
400
500
  • Stock Speed
  • Overclocked
