Adobe Photoshop Elements 4.0
For our Photoshop Elements test, we used a selection of 400 3 Megapixel photographs taken in a variety of surroundings using the batch file processing function in the Elements Editor. We performed all of the auto fixes, including Auto Levels, Auto Contrast, Auto Colour and Sharpen before resizing the image to 640x480 and saving as a high quality JPEG.
        XFX nForce 680i SLI - 7900 GTX
        XFX nForce 680i SLI - 7900 GTX SLI
        Inno3D nForce 680i SLI - 7900 GTX
        Inno3D nForce 680i SLI - 7900 GTX SLI
        Foxconn N68S7AA - 7900 GTX
        Foxconn N68S7AA - 7900 GTX SLI
        Asus P5N32-E SLI Plus - 7900 GTX
        Asus P5N32-E SLI Plus - 7900 GTX SLI
        EVGA nForce 680i LT SLI - 7900 GTX
        EVGA nForce 680i LT SLI - 7900 GTX SLI
        Asus Commando - 7900 GTX
        Asus Commando - X1900 CF
            331.0
            355.0
            336.0
            356.0
            337.0
            353.0
            327.0
            349.0
            331.0
            352.0
            328.0
            317.0
    Time in Seconds (lower is better)
Performance is very good with an acceptable SLI overhead. It's better than the Inno3D nForce 680i SLI, and on par with the EVGA nForce 680i LT SLI. Overall there's not that much difference in performance across the field, with at most a few seconds separating the boards compared.
File Compression & Encryption:
Our file compression and decompression tests were split into two halves to cover a broad spectrum of performance. The first test we ran was to compress and encrypt the MPEG-2 source file from our video encoding test with the highest quality compression ratio. Secondly, we compressed and encrypted the folder of 400 photographs used in our Photoshop Elements test with the same compression settings.
            114
            114
            113
            119
            112
            113
            108
            109
            115
            115
            112
            115
            96
            96
            95
            97
            100
            101
            94
            94
            102
            97
            95
            103
There's no SLI overhead here but performance is only about average - the Asus P5N32-E SLI Plus came out on top in both scenarios. At least the newer BIOS on the XFX is consistently fast unlike the older BIOS on the Inno3D board.
File Decompression & Decryption:
The two RAR archives created during the compression and encryption tests were then decompressed and decrypted.
            14
            15
            15
            15
            17
            17
            17
            16
            16
            16
            17
            17
          8
          10.5
          13
          15.5
          18
            25
            25
            25
            25
            24
            23
            25
            24
            25
            25
            26
            26
Large file decompression is really very good, but small file decompression is only average. Again the performance spread across the field is very small, with only a few seconds separating the various comparisons made.
