PCMark 8 Video Editing
Video Editing v2 Part 2 (Creative 3.0 test suite)
This workload uses FFmpeg to apply video enhancement filters to a high bitrate H.264 video and then encode it to a format suitable for distribution. The FFmpeg binary used is custom built by Futuremark using a development version of the source available from the project's code repository. The test applies a deshaking filter to a source video at 3,840 x 2160 (4K UHD) before scaling down and outputting at 1,920 x 1,080 (1080p).
PCMark 8 4K Video Editing
Part 2 test
  • Asus Sabertooth X99 (3GHz/4.3GHz)
  • MSI X99S MPower (3GHz/4.25GHz)
  • Gigabyte GA-X99-Gaming 5 (3GHz/4.2GHz)
  • ASRock X99E-ITX/ac
  • Gigabyte X99-Gaming 5P (3GHz/4.3GHz)
  • MSI X99A XPOWER AC (3GHz/4.35GHz)
  • Gigabyte GA-X99-UD4P (3GHz/4.35GHz)
  • ASRock X99 Extreme 11 (3GHz/4.25GHz)
  • Gigabyte X99M-Gaming 5 (3GHz/4.35GHz)
  • Asus X99-Pro (3GHz/4.35GHz)
  • Asus X99 Deluxe (3GHz/4.25GHz)
  • ASRock Fatal1ty X99M Killer (3GHz/4.3GHz)
  • MSI X99S SLI Plus (3GHz/4.3GHz)
  • EVGA X99 Micro (3GHz/4.2GHz)
    • 137
    • 112
    • 137
    • 114
    • 137
    • 116
    • 138
    • 112
    • 138
    • 112
    • 138
    • 110
    • 138
    • 111
    • 138
    • 114
    • 138
    • 111
    • 138
    • 111
    • 138
    • 114
    • 142
    • 112
    • 142
    • 112
    • 143
    • 115
50
75
100
125
150
Seconds, lower is better
  • Stock
  • Overclocked
PCMark 8 Photo Editing V2
This workload involves making a series of adjustments to a set of photographs using ImageMagik - an open-source image processing library to adjust brightness, contrast, saturation and gamma. When a favourable balance is found, the changes are then applied to the rest of the images in the set. TIFF files up to 67MB in size are used.
Load image matrix + adjusting times
  • ASRock X99E-ITX/ac (3GHz/4.3GHz)
    • 32
    • 27
    • 32
    • 28
    • 32
    • 29
    • 32
    • 29
    • 33
    • 29
    • 33
    • 27
    • 34
    • 27
    • 34
    • 28
    • 34
    • 28
    • 35
    • 28
    • 36
    • 30
    • 37
    • 31
    • 36
    • 31
    • 36
    • 32
20
30
40
  • Stock
  • Overclocked
