SATA and M.2 Performance
Website: ATTO Disk Benchmark
We tested the SATA and performance with an OCZ Vector 150 240GB, as this is one of the fastest SSDs we've ever tested, and it can saturate the bandwidth of SATA 6Gbps ports.
For M.2 port testing, we used a Plextor PX-G256M6e SSD. This is rated at 770MB/sec read and 580MB/sec write speeds - not quite saturating the M.2 interface but we've been unable to get our mitts on anything faster for long term testing as the interface is still in its infancy.
We use ATTO Disk Benchmark, and take the read and write speeds for 1,024KB data chunks.
        ASRock X99E-ITX/ac  (M.2)
        Gigabyte GA-X99-UD4P (M.2)
        Gigabyte X99-Gaming 5P (M.2)
        ASRock X99 Extreme 11 (M.2)
        Gigabyte X99M-Gaming 5 (M.2)
        Asus X99 Deluxe (M.2)
        MSI X99A XPOWER AC (M.2)
        ASRock Fatal1ty X99M Killer (M.2)
        Gigabyte GA-X99-Gaming 5 (M.2)
        MSI X99S SLI Plus (M.2)
        Asus Sabertooth X99 (M.2)
        MSI X99S MPower (M.2)
        Asus X99-Pro (M.2)
        ASRock X99 Extreme 11 (LSI SAS 3008)
        MSI X99A XPOWER AC (X99 SATA 6Gbps)
        Gigabyte X99M-Gaming 5 (X99 SATA 6Gbps)
        Gigabyte GA-X99-UD4P ( X99 SATA 6Gbps)
        Asus Sabertooth X99 (X99 SATA 6Gbps)
        ASRock X99 Extreme 11 (X99 SATA 6Gbps)
        ASRock X99E-ITX/ac (X99 SATA 6Gbps)
        ASRock Fatal1ty X99M Killer (X99 SATA 6Gbps)
        EVGA X99 Micro (X99 SATA 6Gbps)
        Asus X99 Deluxe (X99 SATA 6Gbps)
        Asus X99-Pro (X99 SATA 6Gbps)
        MSI X99S SLI Plus (X99 SATA 6Gbps)
        Gigabyte GA-X99-Gaming 5 (X99 SATA 6Gbps)
        Gigabyte X99-Gaming 5P (X99 SATA 6Gbps)
        MSI X99S MPower (X99 SATA 6Gbps)
        Asus X99 Deluxe (ASMedia SATA 6Gbps)
          200
          300
          400
          500
          600
          700
          800
    MB/sec, higher is better
Rightmark Audio Analyzer
Publisher: Rightmark
We've recently started testing motherboards using RightMark Audio Analyzer. We use the Playback/Recording test, first adjusting levels so they're within the benchmark parameters and then using 24-bit 192KHz tracks, we connect the line-in to the speaker/line-out jack using a standard 3.5mm audio cable. Following feedback we felt it important to include some results given that on-board audio is a hotly fought-over area with motherboards at the moment.
        Asus Sabertooth X99
        ASRock X99E-ITX/ac
        MSI X99A XPOWER AC
        Asus X99 Deluxe
        EVGA X99 Micro
        Asus X99-Pro
        MSI X99S SLI Plus
        MSI X99S MPower
Higher is better
        Asus Sabertooth X99
        ASRock X99E-ITX/ac
        MSI X99A XPOWER AC
        Asus X99 Deluxe
        Asus X99-Pro
        EVGA X99 Micro
        MSI X99S MPower
        MSI X99S SLI Plus
Lower is better (figures are negative)
        Asus X99 Deluxe
        MSI X99S SLI Plus
        Asus X99-Pro
        Asus Sabertooth X99
        ASRock X99E-ITX/ac
        MSI X99A XPOWER AC
        EVGA X99 Micro
        MSI X99S MPower
          0.005
          0.0075
          0.01
          0.0125
    Lower is better
