Cooler Master Seidon 120M Review
January 3, 2013 | 15:09
Tags: #all-in-one-liquid-cooler #cpu-cooler #seidon-120m #water-cooling
Companies: #cooler-master
Testing and Results
We measure the CPU temperature of our test rigs when the CPU is idle (Windows desktop) and under load (by running the smallfft test in Prime95). We use the freeware application CoreTemp to measure the temperature of the Intel CPUs, which reads the data from the DTS (digital thermal sensor) embedded in the core of every modern CPU. The DTS gives a far more accurate reading than any third-party temperature sensor, because its readings are not affected by sloppy BIOS programming or a poorly calibrated external health monitoring chip on the motherboard.
Because we don't have a temperature control chamber, it's more accurate to measure and quote the delta T (difference) between the ambient and CPU temperature. This means HSFs (heatsinks and fans) that were tested on different days, when the ambient temperature may have varied, can be fairly compared to one another. You'll find the temperature results for the reference HSFs in the graphs. We normally compare the results of each cooler to the reference cooler.
However for the Socket AM3+ and LGA2011 systems, we didn't have the reference coolers for these at time of testing, so the cooling scores are compared against other coolers rather than how much better the cooler was than the reference cooler.
LGA1155 test system:
  • Core i7-2600K overclocked to 4.1GHz using a vcore of 1.325V
LGA2011 test system:
  • Core i7-3960X Extreme Edition overclocked to 4.3GHz using a vcore of 1.285V
Socket AM3 test system:
  • FX-8150 overclocked to 4.4GHz with a vcore of 1.325V
Each test rig is built inside a SilverStone PS03 midi-tower case and includes an Nvidia GeForce 9600 GT graphics card. The temperatures shown are the delta T between ambient and CPU temperature.
Intel LGA1155 CPU delta T
Arranged by 100 per cent CPU load delta T value
  • Corsair H100i Maximum Profile
  • Corsair H100i Balanced Profile
  • Corsair H80i Maximum Profile
  • Corsair H100i Quiet Profile
  • Antec Kühler H2O 920 (Extreme Profile)
  • Thermaltake Water 2.0 Pro
  • Corsair H80i Balanced Profile
  • Thermaltake Water 2.0 Performer
  • Arctic Freezer i30
  • Be Quiet! Dark Rock Pro 2
  • Phanteks PH-TC14PE full speed
  • Thermalright Macho Rev.A
  • Corsair H80i Quiet Profile
  • Be Quiet Dark Rock Pro
  • Zalman CNPS14X
  • Enermax ETS-T40-TA
  • Cooler Master Seidon 120M (Exhaust)
  • Cooler Master Seidon 120M (Intake)
  • Phanteks PH-TC14PE low speed
  • Be Quiet! Shadow Rock TopFlow SR1
  • Be Quiet! Dark Rock Advanced
  • Gelid Tranquillo Rev2
  • Noctua NH-L12
  • Thermolab Trinity high speed
  • Antec Kühler H2O 920 (Silent Profile)
  • Thermolab Trinity low speed
  • Noctua NH-L12 (Single Fan)
  • Phanteks PH-TC90LS
  • Arctic Freezer 11 LP
  • Intel Reference Cooler
    • 4
    • 31
    • 4
    • 33
    • 4
    • 34
    • 5
    • 34
    • 4
    • 36
    • 4
    • 36
    • 4
    • 36
    • 4
    • 38
    • 3
    • 39
    • 4
    • 39
    • 5
    • 39
    • 5
    • 40
    • 5
    • 40
    • 6
    • 40
    • 5
    • 41
    • 5
    • 41
    • 6
    • 41
    • 6
    • 41
    • 7
    • 41
    • 5
    • 43
    • 7
    • 43
    • 6
    • 44
    • 10
    • 45
    • 6
    • 46
    • 6
    • 48
    • 8
    • 49
    • 11
    • 53
    • 12
    • 58
    • 6
    • 61
    • 10
    • 73
20
30
40
50
60
70
80
Delta T (°C) (lower is better)
  • idle
  • Load
Intel LGA2011 CPU delta T
  • Intel Thermal Solution RTS2011LC
  • Zalman CNPS14X
  • Be Quiet Dark Rock Pro (with LGA2011 mount kit)
    • 12
    • 44
    • 14
    • 46
    • 12
    • 47
    • 12
    • 48
    • 13
    • 50
    • 13
    • 51
    • 14
    • 54
    • 14
    • 55
    • 14
    • 56
    • 14
    • 56
    • 16
    • 57
    • 14
    • 57
    • 15
    • 57
    • 14
    • 59
    • 12
    • 61
    • 12
    • 61
    • 13
    • 62
    • 16
    • 62
20
30
40
50
60
  • idle
  • Load
AMD Socket AM3+ CPU delta T
  • Gelid GX-7
  • Zalman CNPS14X
    • 9
    • 36
    • 9
    • 38
    • 9
    • 40
    • 10
    • 42
    • 8
    • 43
    • 10
    • 44
    • 8
    • 45
    • 8
    • 45
    • 9
    • 46
    • 9
    • 47
    • 8
    • 48
    • 9
    • 48
    • 9
    • 50
    • 9
    • 50
    • 9
    • 53
    • 10
    • 53
    • 11
    • 55
    • 12
    • 55
    • 11
    • 56
    • 10
    • 56
    • 10
    • 56
    • 10
    • 57
20
30
40
50
60
  • idle
  • Load
Head over the page to see the performance analysis and scores
ASUS ROG Pugio II Gaming Mouse
April 3 2020 | 14:09
