Swiftech H2O-220 Apex Ultima
Written by James Gorbold
April 30, 2009 | 09:33
Tags: #apex #core-i7 #ultima
Companies: #swiftech
Manufacturer: Swiftech
UK Price (as reviewed): £195.41 (inc. VAT)
US Price (as reviewed): $269.95 (ex. Tax)
Late last year, Intel introduced the Core i7 series of desktop CPUs, based on its Nehalem architecture, and more recently a full range of workstation/server Xeon 5500 series CPUs based on the same architecture. However, although these new CPUs deliver amazing performance they also draw a lot of power so emit a lot of waste heat. As a result, Harry and the guys at Custom PC have spent the last few months trying to find the best way to keep a Core i7 cool - especially when it's overclocked.
Although we've found some great air coolers, this is the first time we've taken a look at a water-cooling kit specifically designed for Core i7. Yes, we know there's a certain elitism in the enthusiast market about buying a water-cooling kit rather than separate components, but what makes this kit a little different is that it comprises a selection of high-end components - not bargain basement bits that struggle to outperform an air cooler.
The benefit to you is that the box not only includes all the major accessories you'll need to watercool a Core i7 CPU, but also all the fixtures and fittings you might need. This means you shouldn't run into the infinitely annoying situation of ordering a load of watercooling components from your favourite etailer, only to find you're missing some barbs/clips when it comes to putting it all together. In addition, while the Apex UItima isn't specifically designed as 'my first water-cooling kit', it does include a fully-illustrated 17 page A4 manual with a step-by-step guide on how to assemble a loop.
Swiftech H2O-220 Apex Ultima Introduction
The Swiftech is a complete CPU water-cooling kit
Over the following pages we'll take a closer look at the all the components included in the Apex UItima and its cooling capability, but for starter's here's a brief overvew of its major selling points:
Swiftech H2O-220 Apex Ultima details
  • CPU waterblock: Swiftech Apogee GTZ
  • Radiator: Swiftech MCR220-QP (dual 120mm fan)
  • Pump: Swiftech MCP655-B
  • Fans: 2 x 120mm Xinruilian RDM1225S
  • Reservoir: Swiftech MCRES-Micro Rev 2
  • Tubing: Eight feet 7/16in ID PVC
  • TIM: Arctic Ceramique
  • Coolant additive: Swiftech Hydrx
  • Accessories: Swiftech Smartcoils 625 Blue, Swiftech MCB-120 Radbox, 2 x 7V resistor cables, 2 x 5V adaptor cables
Mod of the Month May 2021 in Association with Corsair
June 18 2021 | 12:30
