What's the best supersize case fan?
Written by bit-tech Staff
October 9, 2009 | 10:30
Tags: #200mm #airflow #best #big #buy #case #cfm #compare #comparison #dba #fan #guide #large #noise #rated #should-i #sound #tested #what
Companies: #bit-tech #test #which
Index 2: Airflow - 120mm Fans
Remember that how much air a fan can push isn't everything - you should also see how loud a fan is, and possibly most importantly, how much air it can push per dBA.
The 120mm Scythe Gentle Typhoon and Sharkoon Silent Eagle 1000 have been included for reference as they're our favourite 120mm fans. Please read how we tested to see how we generated these results and what they mean.
Airflow
Minimum airflow test level is 6cfm
  • Antec Big Boy 200 (200mm, max speed)
  • Yate Loon D22BL-12H (220mm)
  • Yate Loon D22SL-12H (220mm)
  • Scythe Gentle Typhoon D1225C12B4AP-14 (120mm)
  • ichbinleise 225mm/800rpm (225mm, max speed)
  • Antec Big Boy 200 (200mm, medium speed)
  • Akasa AK-F2230SM-CB
  • Sharkoon Silent Eagle 1000 (120mm)
  • Antec Big Boy 200 (200mm, min speed)
  • Akasa AK-F1825SM-CB (180mm)
  • ichbinleise 225mm/800rpm (225mm, min speed)
  • 121
  • 76
  • 61
  • 61
  • 51
  • 47
  • 43
  • 36
  • 6
  • 6
  • 0
50
75
100
125
Airflow (cubic feet per minute, or cfm)
NOTE: The ichbinleise fan refused to spin at minimum speed, therefore it failed this test at this setting.
