AMD Phenom II 810, 805, 720 & 710 AM3 CPUs
February 11, 2009 | 08:57
Tags: #2 #45nm #710 #720 #805 #810 #am2 #am3 #benchmark #consumption #cpu #crysis #ddr3 #efficiency #ii #performance #phenom #power #result #review #x3 #x4
Companies: #amd #test
Crysis
Publisher: Electronic Arts
Crysis is seen by many as the poster boy for DirectX 10 and it will make your system quite literally fall over crying if it's not up to – it’s a monster of an engine! It doesn’t come as much of a surprise then, that the graphics are something special – they’re above and beyond anything we’ve ever seen in a PC game even still. We used the latest 1.21 patch and range the game in 64-bit and DirectX 10 mode in a custom level run through.
Crysis
1680x1050 0AA 0AF, All High Settings
  • Core i7 965 (4x3.2GHz, 6.4GHz QPI, SMT enabled)
  • Core i7 940 (4x2.93GHz, 4.8GHz QPI, SMT enabled)
  • Core 2 Extreme QX9770 (4x3.2GHz, 1,600MHz FSB, DDR3)
  • Core 2 Extreme QX9770 (4x3.2GHz, 1,600MHz FSB, DDR2)
  • Core i7 920 (4x2.66GHz, 4.8GHz QPI, SMT enabled)
  • Core 2 Quad Q9650 (4x3.0GHz, 1,333MHz FSB, DDR3)
  • Core 2 Duo E8500 (2x3.16GHz, 1,333MHz FSB, DDR3)
  • Core 2 Quad Q9650 (4x3.0GHz, 1,333MHz FSB, DDR2)
  • Core 2 Quad Q9550 (4x2.83GHz, 1,333MHz FSB, DDR3)
  • Core 2 Quad Q9450 (4x2.66GHz, 1,333MHz FSB, DDR3)
  • Core 2 Quad Q9550 (4x2.83GHz, 1,333MHz FSB, DDR2)
  • Core 2 Duo E8500 (2x3.16GHz, 1,333MHz FSB, DDR2)
  • Core 2 Quad Q9450 (4x2.66GHz, 1,333MHz FSB, DDR2)
  • AMD Phenom II X4 940 (4x3.0GHz, 1.8GHz HTT)
  • Core 2 Quad Q6700 (4x2.66GHz, 1,066MHz FSB, DDR2)
  • AMD Phenom II X3 720 BE (3x2.8GHz, 2.0GHz HTT, DDR2)
  • AMD Phenom II X4 920 (4x2.8GHz, 1.8GHz HTT)
  • AMD Phenom II X3 720 BE (3x2.8GHz, 2.0GHz HTT, DDR3)
  • Core 2 Quad Q6700 (4x2.66GHz, 1,066MHz FSB, DDR3)
  • AMD Phenom II X4 (4x2.6GHz, 2.0GHz HTT)
  • AMD Phenom II X4 810 (4x2.6GHz, 2.0GHz HTT, DDR2)
  • AMD Phenom II X3 710 (3x2.6GHz, 2.0GHz HTT, DDR2)
  • AMD Phenom II X3 710 (3x2.6GHz, 2.0GHz HTT, DDR3)
  • AMD Phenom II X4 805 (4x2.5GHz, 2.0GHz HTT, DDR2)
  • AMD Phenom II X4 810 (4x2.6GHz, 2.0GHz HTT, DDR3)
  • AMD Phenom II X4 805 (4x2.5GHz, 2.0GHz HTT, DDR3)
  • AMD Phenom X4 9950 BE (4x2.6GHz, 2.0GHz HTT)
  • AMD Phenom X4 9850 BE (4x2.5GHz, 2.0GHz HTT)
  • AMD Phenom X3 8750 BE (3x2.4GHz, 1.8GHz HTT)
  • AMD Athlon X2 7750 BE (2x2.7GHz, 1.8GHz HTT)
    • 41.7
    • 40.8
    • 39.8
    • 39.3
    • 39.0
    • 38.9
    • 38.7
    • 38.4
    • 38.3
    • 38.2
    • 38.0
    • 37.9
    • 37.8
    • 36.9
    • 36.7
    • 36.1
    • 35.9
    • 35.8
    • 35.5
    • 34.8
    • 34.5
    • 34.5
    • 33.9
    • 33.8
    • 33.0
    • 32.6
    • 32.3
    • 31.4
    • 30.2
    • 29.1
20
30
40
Frames Per Second - higher is better
  • FPS
The AM3 CPUs haven't made a big impact here - certainly one that isn't a greater benefit than clock frequency as the DDR2 AM2+-only Phenom II X4 940 is still faster by an inch or two. The landscape is still mostly in Intel's favour, with only the Core 2 Quad Q6700 with its slower front side bus sitting in amongst the AMDs. The E8500 benefits from a few extra fps over the Phenom II X3 720, although it is also a little more expensive too.
