PCMark Vantage x64
Publisher: Futuremark
PCMark Vantage x64 is a Vista-only 64-bit productivity benchmark that tests a range of standard application types providing a general performance number in respect to other systems.
It tests multi-core processors and requires a processor with at least SSE2 support and a graphics card that supports Shader Model 2.0 or higher.
There are test scenarios for High Definition TV and Movies, Gaming, Memory, Music, Communications, Internet, General Productivity and Hard Drive. They cover the broad range of typical software a PC user will use and acts as a good "one stop" benchmark for general system performance.
Core i7 965 (4x3.2GHz, 6.4GHz QPI, SMT enabled)
Core i7 940 (4x2.93GHz, 6.4GHz QPI, SMT enabled)
Core 2 Extreme QX9770 (4x3.2GHz, 1,600MHz FSB, DDR3)
Core 2 Quad Q9650 (4x3.0GHz, 1,333MHz FSB, DDR3)
Core 2 Extreme QX9770 (4x3.2GHz, 1,600MHz FSB, DDR2)
AMD Phenom II X4 940 (4x3.0GHz, 1.8GHz HTT)
Core 2 Quad Q9550 (4x2.83GHz, 1,333MHz FSB, DDR3)
Core 2 Quad Q9650 (4x3.0GHz, 1,333MHz FSB, DDR2)
AMD Phenom II X4 920 (4x2.8GHz, 1.8GHz HTT)
Core 2 Quad Q9550 (4x2.83GHz, 1,333MHz FSB, DDR2)
Core i7 920 (4x2.66GHz, 6.4GHz QPI, SMT enabled)
AMD Phenom II X3 710 (3x2.6GHz, 2.0GHz HTT, DDR3)
AMD Phenom II X3 720 BE (3x2.8GHz, 2.0GHz HTT, DDR3)
AMD Phenom II X4 805 (4x2.5GHz, 2.0GHz HTT, DDR3)
AMD Phenom II X4 810 (4x2.6GHz, 2.0GHz HTT, DDR3)
Core 2 Quad Q9450 (4x2.66GHz, 1,333MHz FSB, DDR3)
Core 2 Quad Q6700 (4x2.66GHz, 1,066MHz FSB, DDR3)
Core 2 Duo E8500 (2x3.16GHz, 1,333MHz FSB, DDR3)
AMD Phenom II X3 720 BE (3x2.8GHz, 2.0GHz HTT, DDR2)
AMD Phenom II X4 805 (4x2.5GHz, 2.0GHz HTT, DDR2)
Core 2 Quad Q6700 (4x2.66GHz, 1,066MHz FSB, DDR2)
Core 2 Quad Q9450 (4x2.66GHz, 1,333MHz FSB, DDR2)
AMD Phenom II X4 810 (4x2.6GHz, 2.0GHz HTT, DDR2)
AMD Phenom II X4 (4x2.6GHz, 2.0GHz HTT)
AMD Phenom X4 9950 BE (4x2.6GHz, 2.0GHz HTT)
Core 2 Duo E8500 (2x3.16GHz, 1,333MHz FSB, DDR2)
AMD Phenom X4 9850 BE (4x2.5GHz, 2.0GHz HTT)
AMD Athlon X2 7750 BE (2x2.7GHz, 1.8GHz HTT)
AMD Phenom II X3 710 (3x2.6GHz, 2.0GHz HTT, DDR2)
AMD Phenom X3 8750 (3x2.4GHz, 1.8GHz HTT)
2000
3000
4000
5000
6000
Higher is Better
PCMark Vantage x64 chucked out very similar results for all of the new AM3 quad-cores using DDR3, which is a little strange, but the results breakdown (not shown) also varied very little also. The DDR2 numbers however are quite a way down the table, although the 720 again seems like the processor worth looking at as it blitzes its little brother, the 710, while still remaining ahead of its core heavy and more expensive cousins.
DDR3 performance is ahead of a few more expensive Intel quad-cores with both DDR2 and DDR3, and the 720 with DDR2 is still ahead of the Intel Core 2 Duo E8500 and even the quad-core Q9450 at 2.67GHz with DDR2 as well. Overall, it's not industry leading, but price matched - AMD has the advantage here.
