File Compression Performance
WinRAR
Website: WinRAR
Our custom-made file compression test is split into two halves to cover a broad spectrum of performance. The first test compresses and encrypts a 176MB MPEG-2 file with the highest quality compression ratio.
The second test compresses and encrypts a folder of 400 photographs with the same compression settings.
Phenom II X2 550 BE (2x3.8GHz, 2.6GHz NB, 2.0GHz HTT)
Core 2 Duo E7400 (2x4.2GHz, 1,600MHz FSB)
Athlon II X2 250 (2x3.9GHz, 2.4GHz NB, 2.0GHz HTT)
Phenom II X2 550 BE (2x3.1GHz, 2.0GHz NB, 2.0GHz HTT)
Athlon X2 7850 BE (2x3.1GHz, 2.0GHz NB, 2.0GHz HTT)
Pentium Dual Core E5200 (2x4.0GHz, 1,333MHz FSB)
Athlon X2 7850 BE (2x2.7GHz, 1.8GHz NB, 2.0GHz HTT)
Athlon II X2 250 (2x3.0GHz, 2.0GHz NB, 2.0GHz HTT)
Core 2 Duo E7400 (2x2.8GHz, 1,066MHz FSB)
Athlon X2 6000+ (2x3.4GHz, 1.1GHz HTT)
Athlon X2 6000+ (2x3.1GHz, 1.0GHz HTT)
Pentium Dual Core E5200 (2x2.5GHz, 800MHz FSB)
116
118
123
128
139
143
146
151
155
158
173
182
Seconds (lower is better)
94
99
112
112
113
128
131
137
137
150
158
166
50
75
100
125
150
175
In terms of file compression, the results are very good for AMD as the X2 550 BE more or less equals the Intel E7400 when overclocked, and even its stock clock performance is within a second of the highly overclocked Intel E5200 and Athlon II X2 250. Again, like usual, it's much better than the AMD CPUs that have gone before, and at stock speeds at least it's notably faster than the Intel CPUs too.
7-Zip
Download from: 7-Zip
Our community requested the inclusion of 7-Zip, a free alternative to WinRAR, and we've obliged accordingly. We use the internal benchmark, which measures compression and decompression performance in MIPS and provides an average result. It is multi-threaded so takes advantage of the latest multi-core and SMT enabled CPUs. We leave the benchmark to accumulate ten runs using a 32MB Dictionary size in order to get a solid, average result.
7279
7269
7218
6603
6122
5923
5586
5522
5099
5008
4991
4387
2000
3000
4000
5000
6000
7000
8000
MIPS (higher is better)
There is very little difference between the overclocked Intel E7400 and Phenom II X2 550 here - despite the clock speed difference the faster memory performance makes up for it. That said, the much cheaper Athlon II X2 250 is also within a whisker of these two CPUs as well - clearly indicating that the L3 cache makes no difference here.
At stock speeds the 550 again clearly dominates the field thanks to its clock speed, and even for a generally AMD dominated benchmark its clearly faster.
