PCMark Vantage x64
Publisher: Futuremark
PCMark Vantage x64 is a Vista-only 64-bit productivity benchmark that tests a range of standard application types providing a general performance number in respect to other systems.
It tests multi-core processors and requires a processor with at least SSE2 support and a graphics card that supports Shader Model 2.0 or higher.
There are test scenarios for High Definition TV and Movies, Gaming, Memory, Music, Communications, Internet, General Productivity and Hard Drive. They cover the broad range of typical software a PC user will use and acts as a good "one stop" benchmark for general system performance.
Core i7 965 (4x3.2GHz, 6.4GHz QPI, SMT enabled)
Core i7 940 (4x2.93GHz, 6.4GHz QPI, SMT enabled)
Core 2 Extreme QX9770 (4x3.2GHz, 1,600MHz FSB, DDR3)
Core 2 Quad Q9650 (4x3.0GHz, 1,333MHz FSB, DDR3)
Core 2 Extreme QX9770 (4x3.2GHz, 1,600MHz FSB, DDR2)
AMD Phenom II X4 940 (4x3.0GHz, 1.8GHz HTT)
Core 2 Quad Q9550 (4x2.83GHz, 1,333MHz FSB, DDR3)
Core 2 Quad Q9650 (4x3.0GHz, 1,333MHz FSB, DDR2)
AMD Phenom II X4 920 (4x2.8GHz, 1.8GHz HTT)
Core 2 Quad Q9550 (4x2.83GHz, 1,333MHz FSB, DDR2)
Core i7 920 (4x2.66GHz, 6.4GHz QPI, SMT enabled)
Core 2 Quad Q9450 (4x2.66GHz, 1,333MHz FSB, DDR3)
Core 2 Quad Q6700 (4x2.66GHz, 1,066MHz FSB, DDR3)
Core 2 Duo E8500 (2x3.16GHz, 1,333MHz FSB, DDR3)
Core 2 Quad Q6700 (4x2.66GHz, 1,066MHz FSB, DDR2)
Core 2 Quad Q9450 (4x2.66GHz, 1,333MHz FSB, DDR2)
AMD Phenom II X4 (4x2.6GHz, 2.0GHz HTT)
AMD Phenom X4 9950 BE (4x2.6GHz, 2.0GHz HTT)
Core 2 Duo E8500 (2x3.16GHz, 1,333MHz FSB, DDR2)
AMD Phenom X4 9850 BE (4x2.5GHz, 2.0GHz HTT)
AMD Athlon X2 7750 BE (2x2.7GHz, 1.8GHz HTT)
AMD Phenom X3 8750 (3x2.4GHz, 1.8GHz HTT)
2000
3000
4000
5000
6000
Higher is Better
These results for the Phenom II X4 are very good, exceeding the performance results for the Intel Q9550 and even the 3.0GHz Q9650 with DDR2. The Phenom II X4 920 gets an even better result than the Core i7 920 by just over three percent. The CPUs greatly benefit from the increased MHz - far more than a faster memory controller clock alone which does absolutely nothing in the clock to clock performance comparison between generations of Phenom CPUs.
Sony Vegas Studio Platinum 8
Website: Sony Creative Software
Sony Vegas Movie Studio is an industry leading movie making application that offers support for a large variety of video formats. It can handle the latest multi-channel audio and high-definition content, even including AVCHD and HDV. Further features include mixing and editing, video composite creating and video restoration among others. As a highly threaded application it makes great use of multi-core processors.
Here we use the free version: Platinum 8, to transcode a 720x480px 945MB raw .MTS with PCM audio into a 720x480px WMV9 at VBR90, with 5.1 channel 44.1KHz 64Kbps WMA audio.
Core i7 940 (4x2.93GHz, 4.8GHz QPI, SMT enabled)
Core i7 920 (4x2.66GHz, 4.8GHz QPI, SMT enabled)
AMD Athlon X3 8750 BE (3x2.4GHz, 1.8GHz HTT)
Time in Seconds (lower is better)
For Sony Vegas the results are slightly less than impressive than x264 encoding, as the Phenom II's slip down the table a bit below the Q9550s and even Q9450 with DDR3. The Phenom II X4 940 still pulls a 3.5 percent lead ahead of the Q9450 with DDR2, but it's not a huge amount, although the X4 920 is only 0.7 percent slower.
Again the elevated core clock speeds are the bigger winner than a faster memory clock for the Phenom II X4 940 and 920, although in a clock to clock comparison the Phenom II and original Phenom there is another five (or so) percent improvement.
