AMD Phenom II X4 965 BE C3 Review
November 4, 2009 | 09:13
Tags: #2 #benchmarks #c3 #core #cpu #ddr3 #deneb #die #ii #oc #overclock #overclocking #performance #phenom #processor #quad #realworld #review #sleep #x4
Companies: #amd #test
SiSoft Sandra
Download from: www.sisoftware.net
SiSoft Sandra is possibly the most famous 2D benchmarking tool going, and like Lavalys Everest, it has tools to gauge the theoretical performance of every sub-system and component in your PC. Sandra is multi-threaded and we use it to gauge the unbuffered memory performance and the latency of the memory latency.
To run the unbuffered memory test, open the Benchmarks screen, go into the Options and deselect buffering. This will give a more accurate and consistent reading of memory throughput. Then enter the Graphs menu and deselect Animate Controls and Animate Tools - these options are designed for exhibitions like Computex or CES, and are just annoying for end users.
Hit F5 to run the benchmark and once it's finished enter the Graph menu and keep pressing Change Controls Mode until the graphs look like those below. You can now average the Internal Memory Bandwidth and Float Memory Bandwidth numbers to give the unbuffered memory performance.
The latency test is much easier to run - find the Memory Latency tool on the Benchmarks page and just run it by hitting F5. The latency is the top result in the text window.
SiSoft Sandra Memory Bandwidth
  • Intel Core i7-920
  • Intel Core i5-750
  • AMD Phenom II X4 965 C3 Black Edition
  • AMD Phenom II X4 965 Black Edition
  • AMD Phenom II X4 955 Black Edition
    • 18645
    • 28103
    • 16012
    • 19175
    • 12596
    • 15813
    • 12536
    • 15678
    • 12456
    • 16015
10000
15000
20000
25000
30000
MB/s (higher is better)
  • Stock Speed
  • Overclocked
SiSoft Sandra Memory Latency
  • Intel Core i5-750
  • Intel Core i7-920
    • 77
    • 60
    • 84
    • 57
    • 84
    • 66
    • 84
    • 68
    • 84
    • 71
20
30
40
50
60
70
80
90
Nanoseconds (lower is better)
  • Stock Speed
  • Overclocked
At stock speeds the performance again matches the rest of the pack, which is unsurprising given the uniformity of a 2.0GHz memory controller and 1,333MHz CL9 DDR3 across all the Phenom IIs, although even Sandra says the theoretical latency of the overclocked C3 965 Black Edition is a few nanoseconds behind its older brothers.
