Blender
Website: Blender.org
Blender is a free, open source software 32-bit 3D modelling, animation, rendering, post-production, and gaming program. Initially developed by Ton Roosendaal's company NaN in the Netherlands, its popularity, and capabilities, have grown over the years. There is a large and active user base with ongoing development by dedicated hackers, making Blender a powerful and viable 3D software solution.
It can be used for modelling, UV unwrapping, texturing, rigging, skinning, animating, rendering, particle and other simulating, non-linear editing, compositing, and creating interactive 3D applications.
Blender has a robust feature set similar in scope and depth to other high-end 3D software such as Softimage|XSI, Cinema 4D, 3ds Max and Maya. These features include advanced simulation tools such as rigid body, fluid, and soft body dynamics, modifier based modelling tools, powerful character animation tools, a node based material and compositing system and Python for embedded scripting.
        Core 2 Extreme QX9650 (4x3.00GHz, 1333MHz FSB)
        Core 2 Extreme QX6850 (4x3.00GHz, 1333MHz FSB)
        Core 2 Duo E6850 (2x3.00GHz, 1333MHz FSB)
        Core 2 Quad Q6700 (4x2.67GHz, 1066MHz FSB)
        Core 2 Duo E6750 (2x2.67GHz, 1333MHz FSB)
        Core 2 Quad Q6600 (4x2.40GHz, 1066MHz FSB)
        Athlon 64 X2 6400+ (2x3.20GHz, 1.0GHz HTT)
        Phenom 9900 (4x2.6GHz, 2.0GHz HTT)
        Athlon 64 X2 6000+ (2x3.00GHz, 1.0GHz HTT)
        Phenom 9700 (4x2.4GHz, 2.0GHz HTT)
        Phenom 9600 ES (4x2.3GHz, 2.0GHz HTT)
        Phenom 9500 ES (4x2.2GHz, 2.0GHz HTT)
            42.80
            45.23
            45.56
            50.36
            50.86
            55.99
            56.68
            60.18
            61.29
            64.61
            67.13
            69.90
    Time in Seconds (lower is better)
            85.11
            89.46
            89.92
            100.20
            100.33
            111.21
            111.21
            119.89
            124.58
            133.63
            138.19
            143.69
The Blender scores tank, quite frankly. The older Athlon 64 X2s work faster, especially in the single-core test, as they have the clock speed advantage.  However, even the 2.4GHz Intel Q6600 is nearly 17 percent faster than a 2.4GHz Phenom 9700. In the SMP test, Phenom performance is slightly better, but not by much.
Maxon Cinebench 10 x64
Website: Cinebench
Maxon Cinebench is based on Maxon's popular animation software, Cinema 4D, which is used extensively by studios and production houses worldwide for 3D content creation. We've used the built-in CPU benchmark, which uses a 3D scene file to render a photo-realistic image of a concept bike. The scene makes use of various CPU-intensive features such as reflection, ambient occlusion, area lights and procedural shaders.
            13309
            12150
            10855
            10513
            9932
            9669
            9247
            9061
            6648
            5929
            5877
            5344
          5000
          7500
          10000
          12500
          15000
    Score
            3743
            3526
            3506
            3118
            3095
            3037
            2825
            2802
            2718
            2475
            2450
            2317
    Score
Again, single-core performance is pitiful as the low clocked Phenoms can barely keep pace with the rest of the field. However, multi-core performance is far better and the overall performance is within a whisker of a similarly clocked Intel alternative.
