PCMark Vantage x64
Publisher: Futuremark
PCMark Vantage x64 is a Vista-only 64-bit productivity benchmark that tests a range of standard application types providing a general performance number in respect to other systems.
It tests multi-core processors and requires a processor with at least SSE2 support and a graphics card that supports Shader Model 2.0 or higher.
There are test scenarios for High Definition TV and Movies, Gaming, Memory, Music, Communications, Internet, General Productivity and Hard Drive. They cover the broad range of typical software a PC user will use and acts as a good "one stop" benchmark for general system performance.
Core 2 Extreme QX9650 (4x3.00GHz, 1333MHz FSB)
Core 2 Extreme QX6850 (4x3.00GHz, 1333MHz FSB)
Phenom 9900 (4x2.6GHz, 2.0GHz HTT)
Phenom 9700 (4x2.4GHz, 2.0GHz HTT)
Core 2 Quad Q6700 (4x2.67GHz, 1066MHz FSB)
Core 2 Quad Q6600 (4x2.40GHz, 1066MHz FSB)
Core 2 Duo E6850 (2x3.00GHz, 1333MHz FSB)
Core 2 Duo E6750 (2x2.67GHz, 1333MHz FSB)
Phenom 9600 ES (4x2.3GHz, 2.0GHz HTT)
Phenom 9500 ES (4x2.2GHz, 2.0GHz HTT)
Athlon 64 X2 6400+ (2x3.20GHz, 1.0GHz HTT)
Athlon 64 X2 6000+ (2x3.00GHz, 1.0GHz HTT)
5069
4970
4345
4239
4207
4128
4008
3852
3771
3663
3577
3483
2000
3000
4000
5000
PCMarks
TV and Movies
Productivity
Music
Memories
Gaming
Communications
4002
3859
3652
3473
3010
2614
2678
2513
3362
3377
3364
3548
4972
4966
4446
4289
4694
4428
4222
4063
3803
4163
4366
4417
4198
4060
3669
3500
3729
3494
3255
3133
2832
3132
3083
3277
4401
4353
4057
3859
3821
3651
3360
3235
3730
3790
3856
3981
5732
5458
5120
4956
4933
4607
4626
4509
4790
4859
4940
5161
4974
4938
4153
4150
4102
2847
3098
2948
3242
3375
3604
3822
2000
3000
4000
5000
6000
PCMarks
Core 2 Quad Q6700
Core 2 Quad Q6600
Core 2 Duo E6850
Core 2 Duo E6750
Athlon 64 X2 6400+
Athlon 64 X2 6000+
Phenom ES 9500
Phenom ES 9600
Phenom 9700
Phenom 9900
PCMark seems to love Phenom, but it is worth remembering that this is a synthetic benchmark that does do more than you would ever do in terms of productivity and it generally loves multi-cores and good memory performance. The Phenom performance is represented as extremely positive, especially in the TV and Movies benchmark, and it still does quite well in component tests like Communications and Productivity.
