SiSoftware Sandra Lite XII.2008.SP1 (13.12)
Website: Sisoftware
        Phenom X4 9850 (4x2.5GHz, 2.0GHz HTT: Red Turbo Mode)
        Phenom X4 9850 (4x2.5GHz, 2.0GHz HTT: Yellow Turbo Mode)
        Phenom X4 9750 (4x2.4GHz, 1.8GHz HTT: Red Turbo Mode)
        Phenom X4 9550 (4x2.2GHz, 1.8GHz HTT: Red Turbo Mode)
        AMD Phenom 9600 (4x2.3GHz, 1.8GHz HTT)
        AMD Phenom 9500 (4x2.2GHz, 1.8GHz HTT)
        AMD Athlon X2 6400+ (2x3.2GHz, 1.0GHz HTT)
        AMD Athlon X2 6000+ (2x3.0GHz, 1.0GHz HTT)
        Core 2 Duo E8500 (2x3.16GHz, 1,333MHz FSB)
        Core 2 Duo E8400 (2x3.0GHz, 1,333MHz FSB)
        Core 2 Duo E8200 (2x2.66GHz, 1,333MHz FSB)
        Core 2 Duo E6850 (2x3.0GHz, 1,333MHz FSB)
        Core 2 Duo E6750 (2x2.66GHz, 1,333MHz FSB)
        Core 2 Duo E6550 (2x2.33GHz, 1,333MHz FSB)
        Core 2 Quad Q6700 (4x2.67GHz, 1,066MHz FSB)
        Core 2 Duo Q6600 (4x2.40GHz, 1,066MHz FSB)
        Core 2 Duo E4500 (2x2.20GHz, 800MHz)
            8722.2
            8713.2
            8306.8
            8303.0
            8293.8
            8292.3
            7594.5
            7107.7
            6975.3
            6949.8
            6900.3
            6587.2
            6531.2
            6519.5
            5534.2
            5527.3
            4261.3
          2000
          3000
          4000
          5000
          6000
          7000
          8000
          9000
    MB/s
        Core 2 Duo E4500 (2x2.20GHz, 800MHz FSB)
            64
            66
            80
            82
            83
            84
            84
            85
            86
            87
            88
            88
            89
            89
            96
            96
            98
    nanoseconds (lower is better)
Sisoft Sandra loads all the cores when testing memory bandwidth and again the Phenom B3s stand out against the older B2s with improved memory performance and lower latencies. The extra 200MHz northbridge frequency on the 9850 has a significant effect although it's a shame AMD couldn't get this running 1:1 like on the Athlon 64 X2s.
