Aorus Radeon RX 570 Overclocking
The Aorus Engine utility gave us no control over this card's power limit, which is odd. The option was there in Radeon WattMan, however, and we set it to the maximum: 150 percent.
No voltage increase could be applied to the core either, and in the end we only got the card stable at 1,355MHz, which is some way off the 1,430MHz we saw with MSI's Gaming X card. It is, however, always a lottery. The overclock is 75MHz (six percent) higher than the out-of-box frequency, or 111MHz (nine percent) over reference clocks.
The memory did appear to let us increase the voltage, at least in WattMan. Using this, we set a voltage of 1,000mV (100mV more than the 900mV default) and reached 1.95GHz (7.8Gbps effective), an 11 percent boost.
        Asus Radeon RX 580 Strix Gaming Top OC 8GB
        Sapphire Radeon RX 580 Nitro+ 8GB
        Sapphire Radeon RX 480 Nitro+ OC 8GB
        Gigabyte GeForce GTX 1060 G1 Gaming 6GB
        Sapphire Radeon RX 480 Nitro+ OC 4GB
        Aorus Radeon RX 570 4GB (OC)
        MSI Radeon RX 570 Gaming X 4GB
        Gigabyte GeForce GTX 1060 WindForce OC 3GB
        Sapphire Radeon RX 470 Nitro+ OC 4GB
          5000
          7500
          10000
          12500
    Score
    Frames Per Second
    Frames Per Second
