Power Consumption (Idle and Gaming)
In order to get an idea of a GPU's power draw, we run our Unigine Valley 1.0 benchmark, which is our most GPU limited test. We use a watt meter to measure the maximum total system power draw during the test, and also take an idle reading at the Windows desktop (3,840 x 2,160).
        Sapphire Radeon R7 370 Nitro 4GB
        Gigabyte GeForce GTX 950 OC 2GB
        Palit GeForce GTX 960 Super JetStream 2GB
        Asus GeForce GTX 970 DirectCU Mini 4GB
        Asus Radeon R9 380X Strix 4GB
        AMD Radeon R9 Nano 4GB
        Nvidia GeForce GTX 980 4GB
        Sapphire Radeon R9 380 Nitro 4GB
        Sapphire Radeon R9 390 Nitro 8GB
        Sapphire Vapor-X R9 290X 4GB OC (reference clocks)
        Nvidia GeForce GTX 980 Ti 6GB
        Gigabyte GeForce GTX 980 Ti Xtreme Gaming Waterforce 6GB
        MSI GeForce GTX 980 Ti Lightning 6GB
        AMD Radeon R9 Fury X 4GB
        Sapphire Radeon R9 Fury Tri-X 4GB
        Sapphire Radeon R9 390X Tri-X 8GB
    System Power Draw in Watts (lower is better)
Thermal Performance (Idle and Gaming)
Thermal output is also measured using Unigine's Valley 1.0 benchmark, as its DirectX 11 features will stress all parts of a modern GPU. The GPU is installed in a closed, but fairly well ventilated case (Corsair Graphite 760T) with HDD cages removed and the case fans at full speed. We leave all GPU fan profiles and settings as they come and leave the benchmark running for ten minutes so that temperatures plateau. We record the peak GPU temperature using GPU-Z, and present the data as the delta T (the difference between the GPU temperature and the ambient temperature in our labs). We also take an idle reading at the Windows desktop (3,840 x 2,160).
        Asus GeForce GTX 980 Ti Poseidon 6GB (water-cooled)
        Asus GeForce GTX 950 Strix 2GB
        Gigabyte GeForce GTX 980 Ti G1 Gaming 6GB
        MSI GeForce GTX 980 Ti Gaming 6GB
        Asus GeForce GTX 980 Ti Strix 6GB
    Delta T in °C (lower is better)
