Sapphire Radeon HD 4890 Vapor-X 2GB review
Written by Antony Leather
August 25, 2009 | 11:16
Tags: #bfg #gpu #graphics-card #gtx-285 #gtx-295 #hd-4770 #hd-4850 #hd-4870 #radeon-hd #single-pcb
Companies: #asus #ati #nvidia #sapphire #xfx
Fallout 3
Fallout 3
Publisher: Bethesda
Fallout 3 is the revival of Interplay’s excellent Fallout series of games following many years out of the limelight. It’s developed and published by Bethesda and, judging by the success of the game, we’ll be seeing more Fallout games in the future.
Despite using the Oblivion engine which is now a few years old, the game looks absolutely stunning. Bethesda has spiced up the graphics a bit since Oblivion and has extended the engine – there are some great explosions, soft shadows and smoke effects that are particularly noteworthy.
We tested the game by manually playing a section of the game that incorporates a number of explosions and effects that you’re likely to experience during your time in post-apocalyptic Washington DC. We recorded the frame rate using FRAPS.
The in-game details were set to their highest values and both anti-aliasing and anisotropic filtering were controlled by the application settings instead of through the driver control panel. This meant that transparency anti-aliasing was enabled, along with HDR and all of the cool smoke effects.
Fallout 3’s engine is by default capped to 60 frames per second, which can make benchmark results very unclear, especially when testing at lower resolutions or with high end graphics cards. To remove the 60FPS cap you’ll need to find the Fallout3.ini file in \Documents\My Games\Fallout3 and edit the file so that iPresentInterval=0. This removes the frame rate cap, and allows us to get a much better idea of a card’s abilities.
Sapphire Radeon HD 4890 Vapor-X 2GB review Fallout 3 Sapphire Radeon HD 4890 Vapor-X 2GB review Fallout 3
Fallout 3
1,680 x 1,050 4xAA 16xAF, Maximum Detail
  • Nvidia GeForce GTX 295 1,792MB
  • ATI Radeon HD 4870 X2 2GB
  • Sapphire Radeon HD 4890 1GB Atomic
  • ATI Radeon HD 4890 1GB
  • Nvidia GeForce GTX 285 1GB
  • Nvidia GeForce GTX 275 896MB
  • Sapphire Radeon HD 4890 Vapor-X 2GB
    • 84.0
    • 49.0
    • 83.7
    • 56.0
    • 82.4
    • 44.0
    • 79.2
    • 38.0
    • 78.2
    • 45.0
    • 73.6
    • 40.0
    • 73.2
    • 37.0
20
30
40
50
60
70
80
90
Frames Per Second
  • Average
  • Minimum
Fallout 3
1,680 x 1,050 8xAA 16xAF, Maximum Detail
    • 83.0
    • 47.0
    • 82.1
    • 49.0
    • 80.4
    • 33.0
    • 78.4
    • 34.0
    • 76.3
    • 32.0
    • 69.8
    • 33.0
    • 64.1
    • 30.0
20
30
40
50
60
70
80
90
Frames Per Second
  • Average
  • Minimum
Fallout 3
1,920 x 1,200 4xAA 16xAF, Maximum Detail
    • 83.6
    • 47.0
    • 82.6
    • 51.0
    • 79.5
    • 38.0
    • 78.8
    • 35.0
    • 74.9
    • 31.0
    • 74.7
    • 39.0
    • 67.1
    • 32.0
20
30
40
50
60
70
80
90
Frames Per Second
  • Average
  • Minimum
Fallout 3
2,560 x 1,600 4xAA 16xAF, Maximum Detail
    • 82.0
    • 49.0
    • 81.1
    • 30.0
    • 63.6
    • 25.0
    • 61.6
    • 27.0
    • 61.1
    • 25.0
    • 58.5
    • 21.0
    • 56.0
    • 23.0
20
30
40
50
60
70
80
90
Frames Per Second
  • Average
  • Minimum
There was very little between the three HD 4890 variants in Fallout 3. At the first test resolution, the Vapor-X strangely managed to post the highest then the lowest scores when we moved from 4xAA to 8xAA. At the final two resolution however, both of which used 4xAA, results were as expected with the Sapphire Radeon HD 4890 1GB Atomic being faster over all with the Sapphire Radeon HD 4890 Vapor-X 2GB coming in second a fair way ahead of the stock card.
