Fallout 3
Publisher: Bethesda
Fallout 3 is the revival of Interplay’s excellent
Fallout series of games following many years out of the limelight.  It’s developed and published by Bethesda and, judging by the success of the game, we’ll be seeing more
Fallout games in the future.
Despite using the
Oblivion engine which is now a few years old, the game looks absolutely stunning.  Bethesda has spiced up the graphics a bit since
Oblivion and has extended the engine – there are some great explosions, soft shadows and smoke effects that are particularly noteworthy.
We tested the game by manually playing a section of the game that incorporates a number of explosions and effects that you’re likely to experience during your time in post-apocalyptic Washington DC.  We recorded the frame rate using FRAPS.
The in-game details were set to their highest values and both anti-aliasing and anisotropic filtering were controlled by the application settings instead of through the driver control panel.  This meant that transparency anti-aliasing was enabled, along with HDR and all of the cool smoke effects.
Fallout 3’s engine is by default capped to 60 frames per second, which can make benchmark results very unclear, especially when testing at lower resolutions or with high end graphics cards. To remove the 60FPS cap you’ll need to find the Fallout3.ini file in \Documents\My Games\Fallout3 and edit the file so that iPresentInterval=0. This removes the frame rate cap, and allows us to get a much better idea of a card’s abilities.
        Nvidia GeForce GTX 280 1GB SLI
        Nvidia GeForce GTX 260+ 896MB SLI
        ATI Radeon HD 4870 1GB CrossFire
        ATI Radeon HD 4870 X2 2GB
        ATI Radeon HD 4870 512MB
          20
          30
          40
          50
          60
          70
          80
          90
    Frames Per Second
          20
          30
          40
          50
          60
          70
          80
          90
    Frames Per Second
          20
          30
          40
          50
          60
          70
          80
          90
    Frames Per Second
          20
          30
          40
          50
          60
          70
          80
    Frames Per Second
          20
          30
          40
          50
          60
          70
          80
          90
    Frames Per Second
          20
          30
          40
          50
          60
          70
          80
    Frames Per Second
          20
          30
          40
          50
          60
          70
          80
    Frames Per Second
The Radeon HD 4870 1GB pretty much dominates the battle between itself and the GeForce GTX 260+ in
Fallout 3 when anti-aliasing is enabled and, when 8xAA is applied, the GTX 280 has a hard time competing as well.  A great example of the Radeon HD 4870 1GB's domination is at 2,560 x 1,600 with 8xAA applied, where the single Radeon is almost as fast as a pair of GeForce GTX 260+ cards in SLI!
That's just one chink in the GeForce GTX 260+ SLI configuration's armour though, as it delivers a strong showing and makes up a lot of lost ground in single card performance at every other setting we tested.
