Intel Core i9-7900X (Skylake-X) Review
Written by bit-tech Staff
June 16, 2017 | 15:58
Tags: #skylake-x #x299
Companies: #intel
Power Consumption
For all of the overclocked performance tests, we disable all power-saving technology in order to give us a consistent set of results, and also best-case performance numbers - even though technologies such as Intel's SpeedStep might only take microseconds to kick in, that can make a difference in some tests.
However, for the stock speed results and power consumption tests, we re-enable everything in order to get a real-world power draw. The power draw is measured via a power meter at the wall, so the numbers below are of total system power draw from the mains, not the power consumption of a CPU itself. Measuring the power draw of any individual component in a PC is tricky to impossible to achieve.
We use Prime95's small FFTs test to put the CPU under 100 percent load, while idle power results are taken with the PC sitting at a Windows Aero-enabled desktop.
Intel Core i9-7900X (Skylake-X) Review Intel Core i9-7900X Review - Power Consumption
Power Consumption (Idle)
Windows 10 desktop
  • AMD Ryzen 7 1800X
  • AMD Ryzen 7 1800X (4GHz)
  • Intel Core i9-7900X
  • Intel Core i7-6950X
  • Intel Core i9-7900X (4.6GHz)
  • Intel Core i7-6950X (4.4GHz)
    • 52
    • 64
    • 70
    • 78
    • 88
    • 138
50
75
100
125
150
Watts (lower is better)
  • Power Consumption
Power Consumption (Load)
Prime95 small FFTs test
  • AMD Ryzen 7 1800X
    • 168
    • 195
    • 259
    • 267
    • 368
    • 378
200
300
400
  • Power Consumption
