Gaming Performance
Publisher: IDEA Games
We test this hugely demanding game at its most challenging settings, with all the detail options set to Very High and High anti-aliasing enabled. For the benchmark itself, we use a 60-second FRAPS run performed within our own custom timedemo. As the benchmark is variable due to AI inconsistencies, tests are performed three times and the average result is used.
You'll also see that we've not included the results for other Z77 boards in this graph as a recent patch to the game has significantly changed its performance characteristics, meaning the results aren't comparable.
Asus P8Z77-I Deluxe
ASRock Z77E-ITX
Frames per second (fps), higher is better
Asus P8Z77-I Deluxe
ASRock Z77E-ITX
50
75
100
125
150
175
Read our
performance analysis.
