Contrast Ratio and White Point
We measure the brightness, black level and white point at five different brightness levels, as well as full brightness using the various onboard presets a given monitor has. The ratio of the brightness (i.e. full white) to the black level, both measured in cd/m
2, gives us the contrast ratio, which you generally want to be as high as possible. The generally accepted ideal white point, also known as colour temperature, is 6,500K.
        Philips BDM4037UW
        AOC G2460PF
        AOC Agon AG271UG
        BenQ Zowie XL2411
        Iiyama G-Master GB2888UHSU-B1
        ViewSonic VX2776-smhd
        Philips Moda 245C7QJSB
        Asus MG28UQ
Ratio (higher is better)
Maximum Brightness
Minimum Brightness
